May I use outside interface ip block in sfr module??
azizur-rahman
Dear Expert,
I am deploying a cisco firepower and don't want to use mgt port. I want to use outside interface ip address to the sfr module. Is is possible?? Please suggest.
Thanks....
Marvin Rhoads
It's not possible.
While you can indirectly access the module console via the ASA console using the "session" command, an ASA Firepower service module requires using the physical management port for event and control channels.
