monitor ftd interface utilization on nms
Wonxie
Level 3
Level 3
I have 2 FTD's being managed by FMC. I wan my nms to show me the interface utilization of the ftds.
In platform settings i added the snmp configs but in solarwinds nms when i add the device it fails the test.
Need some guidance to achieve above.
Regards.
8 Replies 8
what is your FTD platform ?
MHM
Device is Cisco Firepower 2110 is the platform.
Do i need to add the FTD IP in syslog or just fmc ip ?
my fmc is managing 2 regions each region has 2 ftds in ha.
balaji.bandi
There are different ways to configure check below guide :
https://www.cisco.com/c/en/us/support/docs/ip/simple-network-management-protocol-snmp/213971-configure-snmp-on-firepower-ngfw-applian.html
Where is your solarwinds - coming from inside ? check the FMC event Logs when you poll - check any traffic dropping to poll to device port 161.
still issue post below information :
# show run snmp-server
#show run all snmp-server
#capture CAPI trace interface inside match udp any any eq snmp
#show capture CAPI
show snmp-server statistics
BB
Solar winds has its gateway defined on FTD itself.
you need to look logs and use debug to see if the packet hitting FTD ? when you do query.
BB
Marvin Rhoads
Once you have setup the SolarWinds server address as allowed and configured the SNMP version, interface used and community string, you should be querying the management interface of each FTD device.
Here is a working example:
The platform settings allowing SNMP management look like this:
"OrionWebServer" is a network object with a value of the Orion server IP address.
Note the interface details even picked up that the interface shown is a 2 Gbps Etherchannel.
