NAC IB-VG-L2 problem
a7med_magdy
Community Member
I am configuring NAC for my network IB – VG –L2  as following:
CAM vlan 2
CAS vlan 3
Authentication vlan (31,41)
Access vlan (10,20)
CAS eth0 native vlan 999
CAS eth1 native vlan 998
Vlan Mapping untrusted to the trusted as follwing :31 to 10 and 41 to 20
I have attached all the configuration of the CAM , CAS , core switch and the access switch
I have configured access port on the access switch on vlan 10 for a host machine to test
I also have AD and exch. VM on access vlan 2 . I have created a local account to test but nothing
Happen and I don’t know where is my proplem . By the way I did n’t create Authentication server
As I want it to authenticate locally then do the rest of the lab.
Is there a hope to run this lab?
2 Accepted Solutions
Faisal Sehbai
Level 11
Level 11
Ahmed,
Where are you plugging in your client for testing on the access switch? Which port?
Faisal
If you find this post helpful, please rate so others can find the answer easily
Ahmed,
Yes. Unless you put the client on the untrusted side (Vlan 31), it would not cross the CAS and thus won't be authenticated or posture-assessed.
Give that a shot.
HTH,
Faisal
Faisal Sehbai
Level 11
Level 11
Ahmed,
Faisal
Hello Faisal ,
The client machine is connected to port giga 1/0/11
interface GigabitEthernet1/0/11
switchport access vlan 10
switchport mode access !
Do you think I have to put it in access vlan 31 instead of 10
Ahmed,
Give that a shot.
HTH,
Faisal
hello Faisal, it works and it begin to authenticate and download the agent . but after that i begin to test again
and it asks for the User and password (in the lgin page) and nothing happen it doesn't redirect me to anything
or tell me you credentials is invalid . I tested this account on the CAM and works (Authentication syccessful)
I don't know where is the problem!!
