NAT control issue - traffic with and w/o nat allowed
mitchrussell42
Inside, outside, and two discrete DMZs. Inside 100, outside 0, DMZ1 50, DMZ2 40. DMZ1 -> 192.168.7.0/24. DMZ2 -> 192.168.8.0/24.
Wireless APs on DMZ2 - using public DNS, want to hit FTP server on DMZ1 with public address:
nat (DMZ2,DMZ1) source static WAPs WAPs destination static ftp.contres.com criftp service ftp-service ftp-service
criftp is 192.168.7.130.
I'm bench testing this config to replace a PIX. New ASA 5520s with 8.4(2).
I can ftp from 192.168.8.32 to 174.76.57.40 and see the connection on the FTP server.
I can also ftp from 192.168.8.32 to 192.168.7.130 and see the connection on the same FTP server.
Packet trace does not show this to be possible.
But, it is real. There are no bypass paths in my config, the connections show on the firewall for each test case.
HELP!
5 Replies 5
brquinn
We still don't know all the IP addressing. Can you tell us how the WAPs object and the ftp.contres.com object are defined? It is always best when troubleshooting these issues to get the full 'show nat detail output'. This will tell us if any other rules are being matched prior the the rule in question.
Brendan
I'm just going to open a ticket on this item. I'd rather not put too much information on a public forum.
I understand. For your own troubleshooting, the 'show nat detail' command is your friend. Go through the Source pool for each nat entry and try and locate each hit for the Source IP address you are testing. Then check the destination and make sure it matches what is being received in the packets.
Remember, the Manual Nat statements are processed in order. So make sure there are no Manual Nat entries above the entry you wish to use that match the traffic in question.
Good luck!
Brendan
OK, here is an instance with all fake info:
PC3 <--> ASA <--> PC2
PC3 is 5.5.5.2, WinXP, gw 5.5.5.1
PC2 is 192.168.200.100, Ubuntu, gw 192.168.200.1
ASA is 5.5.5.1 outside, 192.168.200.1 inside.
From PC3, I can connect to the NAT of PC2 at 5.5.5.50 with ftp.
Also, from PC3, I can connect to the real address of PC2 at 192.168.200.100 with ftp.
I need to use this style of NAT so I can map three outside IPs with three different services to the same real server.
Isn't this a bug for the private addresses to be exposed to the outside? I know that these are normally routed over the Internet, but routing tables can be manipulated.
Config:
interface Ethernet0/0
switchport access vlan 2
interface Ethernet0/1
interface Ethernet0/2
interface Ethernet0/3
interface Ethernet0/4
interface Ethernet0/5
interface Ethernet0/6
interface Ethernet0/7
interface Vlan1
nameif inside
security-level 100
ip address 192.168.200.1 255.255.255.0
interface Vlan2
nameif outside
security-level 0
ip address 5.5.5.1 255.255.255.0
boot system disk0:/asa842-k8.bin
ftp mode passive
object network obj_any
subnet 0.0.0.0 0.0.0.0
object network public-web
host 5.5.5.55
object network public-ftp
host 5.5.5.50
object network private-server
host 192.168.200.100
object service ftp-obj
service tcp destination eq ftp
access-list outside_access_in extended permit tcp any object private-server eq ftp
access-list outside_access_in extended deny ip any any
pager lines 24
logging enable
logging asdm informational
mtu inside 1500
mtu outside 1500
icmp unreachable rate-limit 1 burst-size 1
asdm image disk0:/asdm-645.bin
no asdm history enable
arp timeout 14400
nat (outside,inside) source static any any destination static public-ftp private-server service ftp-obj ftp-obj
nat (inside,outside) dynamic interface
access-group outside_access_in in interface outside
timeout xlate 3:00:00
timeout conn 1:00:00 half-closed 0:10:00 udp 0:02:00 icmp 0:00:02
timeout sunrpc 0:10:00 h323 0:05:00 h225 1:00:00 mgcp 0:05:00 mgcp-pat 0:05:00
timeout sip 0:30:00 sip_media 0:02:00 sip-invite 0:03:00 sip-disconnect 0:02:00
timeout sip-provisional-media 0:02:00 uauth 0:05:00 absolute
timeout tcp-proxy-reassembly 0:01:00
timeout floating-conn 0:00:00
dynamic-access-policy-record DfltAccessPolicy
user-identity default-domain LOCAL
http server enable
http 192.168.1.0 255.255.255.0 inside
http 192.168.200.0 255.255.255.0 inside
no snmp-server location
no snmp-server contact
snmp-server enable traps snmp authentication linkup linkdown coldstart
telnet timeout 5
ssh timeout 5
console timeout 0
dhcpd auto_config outside
threat-detection basic-threat
threat-detection statistics access-list
no threat-detection statistics tcp-intercept
webvpn
Workaround - black hole technique
If you packet trace both scenarios, you find the 5.5.5.50 access does a translation, but no translation is attempted for 192.168.200.100. Both then match the ACL.
So, put a dummy translation into the NAT statements. I used:
nat (outside,inside) source static any any destination static private-server black-hole service ftp-obj ftp-obj
object network black-hole
  host 172.32.254.254
Now the access to the private address of the server gets translated to a bad address, and dies the death it deserves.
I still contend that allowing access w/o NAT is an unwanted feature on Cisco's part.
