NAT Problem
nohara
Visitor
I am having problems with all VPN users trying to access a web server on the DMZ please see attachment. The VPN users are on the 10.1.67.0\24 network and when I conduct a packet tracer to web server (10.1.24.25) it fails during NAT. The web server is being NAT'd to 50.xxx.xxx.xxx as you can see on the output below. CHComcast = Outside interface.
object network Web_Ingress
 nat (DMZ,CHComcast) static 50.xxx.xxx.xxx
So I figured that the NAT rule could be overriding the routing table so I tried to insert "route-lookup" but get an error.
nat (DMZ,CHComcast) static 50.xxx.xxx.xxx route-lookup
ERROR: Option route-lookup is only allowed for static identity case
I'm not sure what else I can do. Any help would be greatly appreciated.
JP Miranda Z
Hi [email protected],
If you VPN users is supposed to access the webserver with the private ip and not the natted ip you need to create a nat exempt so this traffic is not going to hit the dynamic nat:
nat (dmz,CHComcast) 1 source static obj-10.1.24.25 obj-10.1.24.25o destination staticbj-10.1.67.0\24 obj-10.1.67.0\24  no-proxy-arp route-lookup
This is just an example you need to use the real objects or create them.
That should definitely fix your problem.
If you don't want to exempt this traffic because your VPN users are supposed to reach that server by the public ip you need to do the packet tracer with the destination as the public ip.
Hope this info helps!!
Rate if helps you!!
-JP-
JP Miranda Z
Rate if helps you!!
-JP-
Appreciate the reply JP!
So lets say my VPN users subnet object is obj-10.1.67.0 and the web server object is obj-10.1.24.25
Does the below look correct? I'm assuming the number 1 means the rule will be applied to the top of the list?
nat (dmz,CHComcast) 1 source static obj-10.1.24.25 obj-10.1.24.25 destination static obj-10.1.67.0 obj-10.1.67.0 no-proxy-arp route-lookup
[email protected],
You can also add the nat without the number 1, and yes is to put it on top, and also yes that nat will fix the issue.
Rate if helps you!!
-JP-
I've been doing some researching and I think it's the other way around.
nat (dmz,CHComcast) 1 source static obj-10.1.67.0 obj-10.1.67.0 desitnation static obj-10.1.24.25 obj-10.1.24.25 no-proxy-arp route-lookup
obj-10.1.67.0 = VPN Subnet
obj-10.1.24.25 = DMZ Web server
