NAT Will Not Work
chris.mcdermott
Community Member
I have the following configured on an ASA running 9.1(2)
object network Webserver
Host  10.10.10.1
nat (DMZ,outside) static 208.2.3.4
Access-list knock_knock extended permit tcp any object Webserver eq http
Access-group knock_knock in interface outside
BUT.. I still cannot get to the the webserver from the outside(internet). so I captured some logs and found that the NAT and access list mentioned above are actually working (please see the attached screen capture)
The NAT is definitely working since my independent test from the outside registers as "hits" each time I try to get to the HTTP server. The logs tell me that it Builds and Tears down the attempted connection instantaneously. Since I know that the NAT and the access list on the outside interface are both working components, troubleshooting them would be a waste of time. The Server itself can access the internet(outside) without any issues from behind the DMZ where it lives. I tested it's ability to do so by logging on and browsing the internet (yahoo, CNN etc..) so the basic principles of the server are fine (IP, Gateway Subnet connectivity etc..)
What would you do at this point?
Thanks in advance
vishaw jasrotia
Level 5
Level 5
Hey ,
Please check the output of the following command from the firewall.
#packet-tracer input dmz tcp http http
Marius Gunnerud
If the packet tracer shows as allowed, I would do a packet capture.  This will give us a good idea if the packets is entering and leaving the outside interface, as well as entering and leaving the inside interface.  Please post the results here for further assistance.
here is a link on how to perform a packet capture:
http://www.cisco.com/c/en/us/support/docs/security/asa-5500-x-series-next-generation-firewalls/110117-asa-capture-asdm-config.html
Please remember to rate and select a correct answer
Please remember to select a correct answer and rate helpful posts
