Need ACL Help
cozyk1515
Level 3
Level 3
I posted this on the 501 help but I am not 15 posts in and still no help so I am re-posting.
I have a several devices that I am using from my pix. However I can't seem to prevent HTTP access to a Spcific Public IP Address. This is what I have.
name P.P.P.P Outside ** Public IP Address
object-group network Tac
network-object host X.X.X.X
access-list outside_in permit tcp object-group Tac host Outside eq www
access-list outside_in permit tcp object-group Tac host Outside eq htt
ps
access-list outside_in permit tcp object-group Tac host Outside eq tel
net
access-list outside_in permit tcp object-group Tac host Outside eq ssh
static (inside,outside) Outside Inside netmask 255.255.255.255 0 0
** I do not want HTTP Access to this Public Device.
Gabrielle
acomiskey
Level 11
Level 11
So what you are saying is you can access P.P.P.P/http from ip addresses other than those defined in object-group Tac?
Also, how are you testing this? Are you coming from outside the pix or from the inside?
From the outside of the pix.
jaravinthan
Level 2
Level 2
i assume the access-list outside_in is applied on the outside interface on inwards direction. And you have a server which is reachable from internet on port 80.
If you do not want to permit port 80 access apart from Tac add a deny entry towards this public IP from any source.
access-list outside_in extended deny tcp any host Outside eq 80
Hope this helps.
