12-21-2017 05:23 AM - edited 02-21-2020 07:00 AM
Good Morning Cisco Forums,
Long time lurker, first time poster. It's been a few years since I've gotten my hands into an ASA, and I recently got one to mess around with in a home lab situation. I've got it (Mostly) configured, but I've run into an odd issue. I can ping by IP and Name from the ASA itself, but can only ping by IP from clients behind the firewall. Not entirely sure what I am missing. Config below -
ASA Version 8.2(5)
hostname 236ASA
enable password 8Ry2YjIyt7RRXU24 encrypted
passwd 2KFQnbNIdI.2KYOU encrypted
names
interface Ethernet0/0
 nameif outside
 security-level 50
 ip address 192.168.5.254 255.255.255.0
interface Ethernet0/1
 nameif inside
 security-level 100
 ip address 192.168.100.254 255.255.255.0
interface Ethernet0/2
 shutdown
 no nameif
 no security-level
 no ip address
interface Ethernet0/3
 shutdown
 no nameif
 no security-level
 no ip address
interface Management0/0
 shutdown
 no nameif
 no security-level
 no ip address
ftp mode passive
dns domain-lookup outside
dns server-group DefaultDNS
 name-server 4.2.2.2
 name-server 8.8.8.8
 name-server 8.8.4.4
 name-server 208.67.220.220
 name-server 208.67.222.222
access-list inside_access_in extended permit ip any any log disable
access-list OUTSIDE-IN extended permit icmp any any
access-list OutsideToInside extended permit icmp any any
pager lines 24
logging enable
logging asdm informational
mtu outside 1500
mtu inside 1500
no failover
icmp unreachable rate-limit 1 burst-size 1
no asdm history enable
arp timeout 14400
global (outside) 1 interface
nat (inside) 1 192.168.100.0 255.255.255.0 norandomseq
access-group inside_access_in in interface inside
route outside 0.0.0.0 0.0.0.0 192.168.5.1 1
timeout xlate 3:00:00
timeout conn 1:00:00 half-closed 0:10:00 udp 0:02:00 icmp 0:00:02
timeout sunrpc 0:10:00 h323 0:05:00 h225 1:00:00 mgcp 0:05:00 mgcp-pat 0:05:00
timeout sip 0:30:00 sip_media 0:02:00 sip-invite 0:03:00 sip-disconnect 0:02:00
timeout sip-provisional-media 0:02:00 uauth 0:05:00 absolute
timeout tcp-proxy-reassembly 0:01:00
timeout floating-conn 0:00:00
dynamic-access-policy-record DfltAccessPolicy
http server enable
http 192.168.0.0 255.255.255.0 inside
http 192.168.100.0 255.255.255.0 inside
http 10.1.0.131 255.255.255.255 outside
http redirect inside 80
no snmp-server location
no snmp-server contact
snmp-server enable traps snmp authentication linkup linkdown coldstart
crypto ipsec security-association lifetime seconds 28800
crypto ipsec security-association lifetime kilobytes 4608000
crypto ca trustpoint _SmartCallHome_ServerCA
 crl configure
crypto-spam removed
quit
telnet 192.168.100.0 255.255.255.0 inside
telnet timeout 5
ssh timeout 5
console timeout 0
dhcpd address 192.168.100.100-192.168.100.200 inside
dhcpd dns 4.2.2.2 8.8.8.8 interface inside
dhcpd enable inside
no threat-detection basic-threat
no threat-detection statistics access-list
threat-detection statistics tcp-intercept rate-interval 30 burst-rate 400 average-rate 200
webvpn
username admin password Rmrc8sBcdjisO3if encrypted privilege 15
class-map global-class
 match any
policy-map global-policy
 class global-class
  inspect icmp
service-policy global-policy global
prompt hostname context
call-home reporting anonymous
Cryptochecksum:d5911ab6a5f54d903a5528de38094ab0
Any help would be appreciated. And if possible, I'd appreciate as much hand holding as possible. It's been a long time, and I'm still a little fuzzy, as I've more or less floundered my way this far.
12-21-2017 10:53 AM
You are missing NAT.
object network LAN
  subnet 192.168.100.0 255.255.255.0
  nat (inside,outside) dynamic interface
Outside interface have security level 0 for best practice.
-If I helped you somehow, please, rate it as useful.-
12-21-2017 11:04 AM
12-21-2017 11:10 AM
12-21-2017 11:20 AM
The syntax above, nat (inside,outside), doesn't work for this ASA either... unless I'm doing something wrong.
logged in
enable
config t
etc..
How would I remove what you're saying?
12-21-2017 11:28 AM
Yes, as I told that config is to newer versions.
To remove:
no nat (inside) 1 192.168.100.0 255.255.255.0 norandomseq
If possible, try to use other version. I have already faced I problem like that, but I am not sure about the version.
12-21-2017 11:29 AM
Done. No change in regards to being able to access the internet/ping by name from the clients. Any other ideas?
12-22-2017 04:22 AM
12-22-2017 04:23 AM
12-22-2017 04:27 AM
I think it is a good idea.
Erase everything and start again. We may be missing something.
01-08-2018 08:46 AM
That syntax doesn't work in 8.2(5)
12-21-2017 11:02 AM
do you have DNS server configured on your clients behind ASA?
I saw that ASA is configured to delivery the dns address, but confirm that clients are getting the DNS server.
Also, are you using which version? It looks like a very old version...
12-21-2017 11:04 AM
