Need help configuring RDP on asa841-k8.bin
Aaron King
Need some assistance with config RDP to internal host from outside.
With new OS, unable to configure RDP having issue with NAT commands are different.
Thanks.
ASA Version 8.4(1)
hostname RTDALTON01
names
interface Vlan1
description LAN VLAN
nameif inside
security-level 100
ip address 172.20.1.30 255.255.255.0
interface Vlan2
description WAN VLAN
nameif outside
security-level 0
ip address 205.144.212.129 255.255.255.0
interface Ethernet0/0
description sw
interface Ethernet0/1
description CABLE INTERNET WINDSTREAM
switchport access vlan 2
interface Ethernet0/2
interface Ethernet0/3
interface Ethernet0/4
interface Ethernet0/5
interface Ethernet0/6
interface Ethernet0/7
banner motd $
banner motd UNAUTHORIZED ACCESS PROHIBITED
banner motd ******************************************************
banner motd Access to this system and associated network, computer
banner motd resource, or data is restricted to those authorized by
banner motd the company. This system and related networks, resources
banner motd or data may only be used for business purposes of the
banner motd company and its customers.Use by unauthorized individuals
banner motd or for an unauthorized purpose is a violation of Federal
banner motd and/or State law. Violators will be prosecuted.
banner motd *************************************************************************
boot system disk0:/asa841-k8.bin
ftp mode passive
same-security-traffic permit intra-interface
object network obj_any
subnet 0.0.0.0 0.0.0.0
object network RDP_static
host 172.20.1.1
access-list remote_access extended permit tcp any interface outside eq 3389
access-list remote_access extended permit gre any host 205.144.212.15
pager lines 24
logging asdm informational
mtu inside 1500
mtu outside 1500
icmp unreachable rate-limit 1 burst-size 1
no asdm history enable
arp timeout 14400
nat (inside,outside) source static RDP_static interface
nat (inside,outside) source static RDP_static interface destination static obj_any any
nat (inside,outside) dynamic interface
access-group remote_access in interface outside
route outside 0.0.0.0 0.0.0.0 205.144.212.1 1
timeout xlate 3:00:00
timeout conn 1:00:00 half-closed 0:10:00 udp 0:02:00 icmp 0:00:02
timeout sunrpc 0:10:00 h323 0:05:00 h225 1:00:00 mgcp 0:05:00 mgcp-pat 0:05:00
timeout sip 0:30:00 sip_media 0:02:00 sip-invite 0:03:00 sip-disconnect 0:02:00
timeout sip-provisional-media 0:02:00 uauth 0:05:00 absolute
timeout tcp-proxy-reassembly 0:01:00
dynamic-access-policy-record DfltAccessPolicy
aaa authentication ssh console LOCAL
aaa authentication telnet console LOCAL
http server enable
http 192.168.1.0 255.255.255.0 inside
http 172.20.1.0 255.255.255.0 inside
http 0.0.0.0 0.0.0.0 outside
no snmp-server location
no snmp-server contact
snmp-server enable traps snmp authentication linkup linkdown coldstart
telnet 172.20.1.0 255.255.255.0 inside
telnet timeout 5
ssh 0.0.0.0 0.0.0.0 outside
ssh timeout 5
console timeout 0
dhcpd auto_config outside
threat-detection basic-threat
threat-detection statistics access-list
no threat-detection statistics tcp-intercept
webvpn
class-map inspection_default
match default-inspection-traffic
policy-map type inspect dns preset_dns_map
parameters
  message-length maximum 512
policy-map global_policy
class inspection_default
  inspect ftp
  inspect h323 h225
  inspect h323 ras
  inspect rsh
  inspect rtsp
  inspect esmtp
  inspect sqlnet
  inspect skinny
  inspect sunrpc
  inspect xdmcp
  inspect sip
  inspect netbios
  inspect tftp
  inspect pptp
prompt hostname context
call-home
profile CiscoTAC-1
  no active
  destination address http https://tools.cisco.com/its/service/oddce/services/DDCEService
  destination address email callhome@cisco.com
  destination transport-method http
  subscribe-to-alert-group diagnostic
  subscribe-to-alert-group environment
  subscribe-to-alert-group inventory periodic monthly
  subscribe-to-alert-group configuration periodic monthly
  subscribe-to-alert-group telemetry periodic daily
Cryptochecksum:74e822be2c77334d430a8f99f14b0a4e
: end
RTDALTON01(config)#
varrao
Level 10
Level 10
Hi Aaron,
If you use the above natting then you would lose all the management access on the outside interface, you would need to do port forwarding, kindly remove the nat statements that you have and you can use this:
object service rdp_login
  service tcp destination eq 3389
nat (outside,inside) source static any any destination static interface RDP_static service rdp_login rdp_login
and the access-list is also wrong, it should be:
access-list remote_access extended permit tcp any host 172.20.1.1 eq 3389
and it would work smoothly for you.
Hope this helps.
Varun
Varun Rao
