need help port forwarding Cisco ASAv 9.2(3) VMware esxi
systemaxtech
I have Cisco ASAv 9.2(3) running on a VMware virtual machine,
Problem I have is I would like to port forward tcp 3389 to a windows machine,
Now I can access the internet from all the window machines behind the inside network,
below is the show run command, can someone show me the right syntax to port forward 3389 to 10.20.20.3
: Hardware:   ASAv, 4096 MB RAM, CPU Xeon 5500 series 2932 MHz, 1 CPU (3 cores)
ASA Version 9.2(3)
hostname ciscoasa
enable password 8Ry2YjIyt7RRXU24 encrypted
xlate per-session deny tcp any4 any4
xlate per-session deny tcp any4 any6
xlate per-session deny tcp any6 any4
xlate per-session deny tcp any6 any6
xlate per-session deny udp any4 any4 eq domain
xlate per-session deny udp any4 any6 eq domain
xlate per-session deny udp any6 any4 eq domain
xlate per-session deny udp any6 any6 eq domain
names
interface GigabitEthernet0/0
 nameif OUTSIDE
 security-level 0
 ip address 172.16.30.15 255.255.255.0
interface GigabitEthernet0/1
 nameif INSIDE
 security-level 100
 ip address 10.20.20.1 255.255.255.0
interface GigabitEthernet0/2
 shutdown
 no nameif
 no security-level
 no ip address
interface GigabitEthernet0/3
 shutdown
 no nameif
 no security-level
 no ip address
interface GigabitEthernet0/4
 shutdown
 no nameif
 no security-level
 no ip address
interface GigabitEthernet0/5
 shutdown
 no nameif
 no security-level
 no ip address
interface GigabitEthernet0/6
 shutdown
 no nameif
 no security-level
 no ip address
interface GigabitEthernet0/7
 shutdown
 no nameif
 no security-level
 no ip address
interface GigabitEthernet0/8
 shutdown
 no nameif
 no security-level
 no ip address
interface Management0/0
 management-only
 shutdown
 nameif management
 security-level 0
 no ip address
ftp mode passive
dns domain-lookup OUTSIDE
dns server-group DefaultDNS
 name-server 192.168.1.200
object network obj_any
 subnet 10.20.20.0 255.255.255.0
pager lines 23
mtu OUTSIDE 1500
mtu INSIDE 1500
mtu management 1500
no failover
icmp unreachable rate-limit 1 burst-size 1
asdm image disk0:/asdm-741.bin
no asdm history enable
arp timeout 14400
no arp permit-nonconnected
 nat (INSIDE,OUTSIDE) dynamic interface
route OUTSIDE 0.0.0.0 0.0.0.0 172.16.30.1 1
timeout xlate 3:00:00
timeout pat-xlate 0:00:30
timeout conn 1:00:00 half-closed 0:10:00 udp 0:02:00 icmp 0:00:02
timeout sunrpc 0:10:00 h323 0:05:00 h225 1:00:00 mgcp 0:05:00 mgcp-pat 0:05:00
timeout sip 0:30:00 sip_media 0:02:00 sip-invite 0:03:00 sip-disconnect 0:02:00
timeout sip-provisional-media 0:02:00 uauth 0:05:00 absolute
timeout tcp-proxy-reassembly 0:01:00
timeout floating-conn 0:00:00
dynamic-access-policy-record DfltAccessPolicy
user-identity default-domain LOCAL
aaa authentication ssh console LOCAL
http server enable
http 10.20.20.0 255.255.255.0 INSIDE
no snmp-server location
no snmp-server contact
crypto ipsec security-association pmtu-aging infinite
crypto ca trustpool policy
telnet 10.20.20.3 255.255.255.255 INSIDE
telnet 10.20.20.2 255.255.255.255 INSIDE
telnet timeout 5
ssh stricthostkeycheck
ssh 10.20.20.3 255.255.255.255 INSIDE
ssh 10.20.20.2 255.255.255.255 INSIDE
ssh timeout 5
ssh version 2
ssh key-exchange group dh-group1-sha1
console timeout 0
threat-detection basic-threat
threat-detection statistics access-list
no threat-detection statistics tcp-intercept
webvpn
 anyconnect-essentials
username cisco password 3USUcOPFUiMCO4Jk encrypted privilege 15
class-map inspection_default
 match default-inspection-traffic
policy-map type inspect dns preset_dns_map
 parameters
  message-length maximum client auto
  message-length maximum 512
policy-map global_policy
 class inspection_default
  inspect rtsp
  inspect sunrpc
  inspect xdmcp
  inspect netbios
  inspect tftp
  inspect ip-options
  inspect ftp
  inspect h323 h225
  inspect h323 ras
  inspect rsh
  inspect esmtp
  inspect sqlnet
  inspect sip
  inspect skinny
service-policy global_policy global
prompt hostname context
no call-home reporting anonymous
call-home
 profile CiscoTAC-1
  no active
  destination address http https://tools.cisco.com/its/service/oddce/services/DDCEService
  destination address email callhome@cisco.com
  destination transport-method http
  subscribe-to-alert-group diagnostic
  subscribe-to-alert-group environment
  subscribe-to-alert-group inventory periodic monthly 23
  subscribe-to-alert-group configuration periodic monthly 23
  subscribe-to-alert-group telemetry periodic daily
0 Replies 0
