Need help with ASA 5512 and SQL port between DMZ and inside
John Clausen
Hello everyone,
Inside is on gigabitEthernet0/1 ip 192.9.200.254
I have a dmz on gigabitEthernet2 ip 192.168.100.254
I need to pass port 443 from outside to dmz ip 192.168.100.80 and open port 1433 from 192.168.100.80 to the inside network.
I believe this will work for port 443:
object network dmz
subnet 192.168.100.0 255.255.255.0
object network webserver
host 192.168.100.80
nat (dmz,outside) static interface service tcp 443 443
access-list Outside_access_in extended permit tcp any object webserver eq 443
access-group Outside_access_in in interface Outside
However...How would I open only port 1433 from dmz to inside?
At the bottom of this message is my config if it helps.
John Clausen
Config:
: Saved
ASA Version 9.1(2)
hostname ciscoasa-gcs
domain-name router.local
enable password f4yhsdf.4sadf977 encrypted
passwd f4yhsdf.4sadf977 encrypted
names
ip local pool vpnpool 192.168.201.10-192.168.201.50
interface GigabitEthernet0/0
 nameif outside
 security-level 0
 ip address 123.222.222.212 255.255.255.224
interface GigabitEthernet0/1
 nameif inside
 security-level 100
 ip address 192.9.200.254 255.255.255.0
interface GigabitEthernet0/2
 nameif dmz
 security-level 100
 ip address 192.168.100.254 255.255.255.0
interface GigabitEthernet0/3
 shutdown
 no nameif
 no security-level
 no ip address
interface GigabitEthernet0/4
 shutdown
 no nameif
 no security-level
 no ip address
interface GigabitEthernet0/5
 shutdown
 no nameif
 no security-level
 no ip address
interface Management0/0
 management-only
 nameif management
 security-level 100
ftp mode passive
dns server-group DefaultDNS
object network inside-subnet
 subnet 192.9.200.0 255.255.255.0
object network netmotion
 host 192.9.200.6
object network inside-network
object network vpnpool
 subnet 192.168.201.0 255.255.255.192
object network NETWORK_OBJ_192.168.201.0_26
object network NETWORK_OBJ_192.9.200.0_24
access-list outside_access_in extended permit icmp any4 any4 log disable
access-list Outside_access_in extended permit udp any object netmotion eq 5020
access-list split standard permit 192.9.200.0 255.255.255.0
access-list VPNT_splitTunnelAcl standard permit 192.9.200.0 255.255.255.0
pager lines 24
logging asdm informational
mtu outside 1500
mtu inside 1500
mtu management 1500
mtu dmz 1500
icmp unreachable rate-limit 1 burst-size 1
no asdm history enable
arp timeout 14400
no arp permit-nonconnected
nat (inside,outside) source static inside-network inside-network destination static vpnpool vpnpool
nat (inside,outside) source static NETWORK_OBJ_192.9.200.0_24 NETWORK_OBJ_192.9.200.0_24 destination static NETWORK_OBJ_192.168.201.0_26 NETWORK_OBJ_192.168.201.0_26 no-proxy-arp route-lookup
 nat (inside,outside) static interface service udp 5020 5020
nat (inside,outside) after-auto source dynamic any interface
access-group Outside_access_in in interface outside
route outside 0.0.0.0 0.0.0.0 123.222.222.1 1
timeout xlate 3:00:00
timeout pat-xlate 0:00:30
timeout conn 1:00:00 half-closed 0:10:00 udp 0:02:00 icmp 0:00:02
timeout sunrpc 0:10:00 h323 0:05:00 h225 1:00:00 mgcp 0:05:00 mgcp-pat 0:05:00
timeout sip 0:30:00 sip_media 0:02:00 sip-invite 0:03:00 sip-disconnect 0:02:00
timeout sip-provisional-media 0:02:00 uauth 0:05:00 absolute
timeout tcp-proxy-reassembly 0:01:00
timeout floating-conn 0:00:00
dynamic-access-policy-record DfltAccessPolicy
user-identity default-domain LOCAL
http server enable
http 192.168.1.0 255.255.255.0 management
http 192.9.200.0 255.255.255.0 inside
no snmp-server location
no snmp-server contact
snmp-server enable traps snmp authentication linkup linkdown coldstart warmstart
crypto ipsec ikev1 transform-set ESP-3DES-MD5 esp-3des esp-md5-hmac
crypto ipsec ikev1 transform-set ESP-DES-MD5 esp-des esp-md5-hmac
crypto ipsec ikev1 transform-set ESP-3DES-SHA esp-3des esp-sha-hmac
crypto ipsec ikev1 transform-set ESP-AES-128-SHA esp-aes esp-sha-hmac
crypto ipsec ikev1 transform-set ESP-AES-192-SHA esp-aes-192 esp-sha-hmac
crypto ipsec ikev1 transform-set ESP-AES-128-MD5 esp-aes esp-md5-hmac
crypto ipsec ikev1 transform-set ESP-AES-192-MD5 esp-aes-192 esp-md5-hmac
crypto ipsec ikev1 transform-set ESP-AES-256-SHA esp-aes-256 esp-sha-hmac
crypto ipsec ikev1 transform-set ESP-AES-256-MD5 esp-aes-256 esp-md5-hmac
crypto ipsec ikev1 transform-set ESP-DES-SHA esp-des esp-sha-hmac
crypto ipsec security-association pmtu-aging infinite
crypto dynamic-map SYSTEM_DEFAULT_CRYPTO_MAP 65535 set pfs group5
crypto dynamic-map SYSTEM_DEFAULT_CRYPTO_MAP 65535 set ikev1 transform-set ESP-AES-128-SHA ESP-AES-128-MD5 ESP-AES-192-SHA ESP-AES-192-MD5 ESP-AES-256-SHA ESP-AES-256-MD5 ESP-3DES-SHA ESP-3DES-MD5 ESP-DES-SHA ESP-DES-MD5
crypto map outside_map 65535 ipsec-isakmp dynamic SYSTEM_DEFAULT_CRYPTO_MAP
crypto map outside_map interface outside
crypto ca trustpool policy
crypto ikev1 enable outside
crypto ikev1 policy 10
 authentication crack
 encryption aes-256
 hash sha
 group 2
 lifetime 86400
crypto ikev1 policy 20
 authentication rsa-sig
 encryption aes-256
 hash sha
 group 2
 lifetime 86400
crypto ikev1 policy 30
 authentication pre-share
 encryption aes-256
 hash sha
 group 2
 lifetime 86400
crypto ikev1 policy 40
 encryption aes-192
 hash sha
 group 2
 lifetime 86400
crypto ikev1 policy 50
 encryption aes-192
 hash sha
 group 2
 lifetime 86400
crypto ikev1 policy 60
 encryption aes-192
 hash sha
 group 2
 lifetime 86400
crypto ikev1 policy 70
 encryption aes
 hash sha
 group 2
 lifetime 86400
crypto ikev1 policy 80
 encryption aes
 hash sha
 group 2
 lifetime 86400
crypto ikev1 policy 90
 encryption aes
 hash sha
 group 2
 lifetime 86400
crypto ikev1 policy 100
 encryption 3des
 hash sha
 group 2
 lifetime 86400
crypto ikev1 policy 110
 encryption 3des
 hash sha
 group 2
 lifetime 86400
crypto ikev1 policy 120
 encryption 3des
 hash sha
 group 2
 lifetime 86400
crypto ikev1 policy 130
 encryption des
 hash sha
 group 2
 lifetime 86400
crypto ikev1 policy 140
 encryption des
 hash sha
 group 2
 lifetime 86400
crypto ikev1 policy 150
 encryption des
 hash sha
 group 2
 lifetime 86400
telnet 192.9.200.0 255.255.255.0 inside
telnet timeout 5
ssh timeout 5
ssh key-exchange group dh-group1-sha1
console timeout 0
dhcpd address 192.168.1.2-192.168.1.254 management
dhcpd enable management
threat-detection basic-threat
threat-detection statistics access-list
no threat-detection statistics tcp-intercept
ssl encryption aes128-sha1 3des-sha1
webvpn
 enable outside
 anyconnect image disk0:/anyconnect-win-2.5.2014-k9.pkg 2 regex "Windows NT"
 anyconnect image disk0:/anyconnect-macosx-i386-2.5.2014-k9.pkg 3 regex "Intel Mac OS X"
 anyconnect enable
 tunnel-group-list enable
group-policy SSLVPN internal
group-policy SSLVPN attributes
 dns-server value 192.9.200.13
 vpn-tunnel-protocol ssl-client
 split-tunnel-policy tunnelspecified
 split-tunnel-network-list value split
 default-domain value router.local
group-policy VPNT internal
group-policy VPNT attributes
 vpn-tunnel-protocol ikev1 l2tp-ipsec
split-tunnel-network-list value VPNT_splitTunnelAcl
username grimesvpn password 7.wersfhyt encrypted
username grimesvpn attributes
 service-type remote-access
tunnel-group SSLVPN type remote-access
tunnel-group SSLVPN general-attributes
 address-pool vpnpool
 default-group-policy SSLVPN
tunnel-group SSLVPN webvpn-attributes
 group-alias SSLVPN enable
tunnel-group VPNT type remote-access
tunnel-group VPNT general-attributes
 default-group-policy VPNT
tunnel-group VPNT ipsec-attributes
 ikev1 pre-shared-key *****
class-map inspection_default
 match default-inspection-traffic
policy-map type inspect dns preset_dns_map
 parameters
  message-length maximum client auto
  message-length maximum 512
policy-map global_policy
 class inspection_default
  inspect ftp
  inspect h323 h225
  inspect h323 ras
  inspect rsh
  inspect rtsp
  inspect esmtp
  inspect sqlnet
  inspect skinny
  inspect sunrpc
  inspect xdmcp
  inspect sip
  inspect netbios
  inspect tftp
  inspect ip-options
  inspect icmp
service-policy global_policy global
prompt hostname context
no call-home reporting anonymous
Cryptochecksum:36271b5a1b9382621e14c3aa635e2fbb
: end
6 Replies 6
Vibhor Amrodia
Port 443 configuration looks good and should work.
As far as 1433 is concerned , just add this command:-
same-security-traffic permit inter-interface
Thanks and Regards,
Vibhor Amrodia
It may not be a good idea to permit all traffic between your DMZ and inside. Just a thought.
As per the Security Level configured on the DMZ interface , this command would be required.
If as per requirement , you would like to block any traffic , you can always apply an interface ACL.
Thanks and Regards,
Vibhor Amrodia
Hi Vibor. Apologies if my comment was misunderstood.  What I meant to say was that the security level of the dmz interface should probably be less than 100.
And therefore traffic could be controlled between DMZ and inside networks.
As per thr security level on the DMZ interface. ....... that command is correct. :-)
Hi Andre,
No need for apologies as you were correct in pointing this out.
Thank you.
Thanks and Regards,
Vibhor Amrodia
I just put the security level at 100 to get the port going. I will gladly change it to 50. I don't want all traffic between the dmz and inside, just port 1433.
John
