Need help with ASA
vinayak
Level 4
Level 4
hello All,
Recently i purchased 2 ASA 5505 for my network. I am Having 2 Internet connections. I am connected ISP 1 to ASA 1 & ISP 2 to ASA 2.
I want to use ASA 1 For Site-to-Site VPN & ASA 2 for Internet Connection. I am also having Cisco Catalyst 3560 -24 Ports Switch in my network.
Is it possible to use both VPN & Internet links simulteniously from LAN. ??
hobbe
Level 11
Level 11
sure, one easy way of doing it might be to set up static routing in the 3560 and have three "lan",
one lan for the internet asa to the 3560
one lan for the vpnasa to the 3560
one lan for the users and servers.
set up the vpn asa towards the remote site and default gateway towards the isp of that link just as usual.
set up the internet ASA towards internet just as you would do normally with its default gateway towards its isp
on the 3560 enable routing
set up static routing of the remote site networks towards the vpn asa
set up default gateway towards the internet asa.
thats it.
This is just one way of doing it.
good luck
hobbe
Level 11
Level 11
thats it.
good luck
hey,
Thanks for reply.
I have one request. if u dont mind can u please explain me this case with example ?
Please.
Green line = traffic destined for Internet
Red line = traffic destined to 192.168.4.0 through vpn tunnel
3560
3 interfaces in routed mode on the 3560 and IP routing on.
interface 1 = default gateway for the local lan
interface 2 = routed interface towards the vpn gateway.
interface 3 = routed interface towards the internet gateway
3560 default gateway = the Internet FW Interface
192.168.4.0 is routed through the VPN fw interface
VPN Firewall default gateway = isp router
Internet FW default gateway = isp router
exchange the ip addresses for your own ip address scheme.
