need help with two T1s and static routes on ASA 5505 with sec plus license
I have Two T1 lines coming into our office. 1 is a full connected to it's own router (ISP's router). We also have another T1 that is split between voice and data (also terminates in another one of the same ISP's router). I have the default route set to the full T1. I need to configure a static route to send all traffic destined for a certain network out of the split T1. How would I configure this from the command line? I have a vlan for the full T1 (outside) and a vlan for the split T1. Is it possible to configure a static route to send all traffic destined for a particular network out of the vlan connected to the router with the split T1?
snickered
Sure, a static route would work. If the nameif of your vlan you want to go out of is "split", the network you want to reach is "172.30.0.0/24" and the next-hop the ASA is connected to is "10.0.0.1" then you would do:
route split 172.30.0.0 255.255.255.0 10.0.0.1
