I am trying to setup a FMC 1600 appliance and have been told it's connected to it's serial port via a serial console server.
However, when I log into the cli, I get the following prompt: FMC cli->
I cannot type anything in there (I've tried ?, help, show, setup, etc. without any luck) A only get a "Error: Invalid command:" message back.
I suspect they connected it to the CIMC/LOM port instead and I need to know if there is anything I can do to setup this appliance from the CIMC Cli? Can I switch shell to the normal FMC CLI?
