OSPF Error on HA PIX not running OSPF?
slug420
Have a pair of PIXs running 6.3(5) that are configured for failover. I ran into this error a couple times while initially trying to configure the firewalls and wound up doing a write erase on each and starting the config from scratch. I still saw this error thuogh while testing failover.
Neither firewalls is or has ever been (new out of box) configured to run OSPF in any capacity and as far as I know there isnt even any ospf on our network. "sh run" shows no ospf related configurations.
Any ideas what this means?
%No matching route to deleteWARNING: unable to remove route from OSPF RIB
Cannot remove route entry because it does not exist
smalkeric
Level 6
Level 6
To remove the route command from the configuration file and restore the system to its default condition where the software removes specified static routes, use the no form of this command.
no route {ipv4|ipv6} prefix mask [ip-address] [interface-type interface-number] [distance] [tag tag] [permanent]
