Pıx's telnet problem
dilek.horasan
Community Member
ı didn't connect pıx clı.It always give error about telnet problem.What is the source in this problem.
Would you please tell us the error log you have? You want to connect to PIX via telnet?
you need to tell the pix which hosts/networks are allowed to telnet to the pix. for example if you want just your ip address to telnet, and your ip is 192.168.1.100 you issue "telnet 192.168.1.100 255.255.255.255 inside" If you are running version 7.0+ you also need "management-access inside"
I would not configure telnet, but ssh for remote access. The above post is also on point. You can do that with ssh.
