P2P and IM blocking with ASA 5520 using GUI
Hi everyone,
We have an ASA 5520 working since somedays, and we want now to block IM and P2P network traffic through our firewall. We asked our distributor and they send us a link: http://www.cisco.com/en/US/products/ps6120/products_configuration_example09186a00808c38a6.shtml
In this link we have information about blocking such traffic by modifying directly in the running-config file. Our question is whether we can find or not a way to do it using the GUI. We will fell safer if we do it like this.
In case there is no chance to do it through GUI, how should I proceed to modify running-config file.
Thank you.
hadbou
Level 5
Level 5
Here is a sample for blocking IM and P2P
Create a class-map for http inspection
pix(config)# class-map http-port
pix(config-cmap)# match port tcp eq 80
pix(config-cmap)# exit
Create an http-map to specify parameters for inspect http
pix(config)# http-map inbound_http
pix(config-http-map)# content-length min 100 max 2000 action reset log
pix(config-http-map)# content-type-verification match-req-rsp action reset log
pix(config-http-map)# max-header-length request 100 action reset log
pix(config-http-map)# max-uri-length 100 action reset log
pix(config-http-map)# port-misuse p2p action drop
pix(config-http-map)# port-misuse im action drop
pix(config-http-map)# port-misuse default action allow
pix(config-http-map)# exit
Create a policy-map for http inspection
*pix(config)# policy-map inbound_policy
pix(config-pmap)# class http-port
pix(config-pmap-c)# inspect http inbound_http
pix(config-pmap-c)# exit
pix(config-pmap)# exit
If necessary create a service-policy or use the default-inspection policy:
pix(config)# service-policy inbound_policy interface outside
hi hadbou,
thank you very much for your answer.
There's just a little point on it. I'm able to create the class-map and the police map fine. Unfortunately when I tried to create an http-map to specify parameters for inspecting http I received the message"This command has been deprecated. Use 'policy-map type inspect http'" and at this point, I don't know how to go on.
I supposed I have a newer version, an such a command is not working any longer. how should I do it?
Thank you for your posts.
