PIX 501 Switch Problem
andyleealbrecht
Community Member
My PIX 501 has been running like a champ for the last 6 months but today when I came home, all of the lights on the switch portion were off. The power light and the light for the 0 port were still lit up but none of the lights for the 1-4 ports were lit up. I haven't made any configuration changes, so I'm not sure why all of a sudden the switch portion would just up and quit. I've powered it off and that didn't make a difference. Any help or ideas would be appreciated. I'd be glad to provide any information needed. Thank you.
15 Replies 15
Here you go:
show interface
interface ethernet0 "outside" is up, line protocol is down
Hardware is i82559 ethernet, address is 0013.c365.defb
MTU 1500 bytes, BW 10000 Kbit half duplex
0 packets input, 0 bytes, 0 no buffer
Received 0 broadcasts, 0 runts, 0 giants
0 input errors, 0 CRC, 0 frame, 0 overrun, 0 ignored, 0 abort
0 packets output, 0 bytes, 0 underruns
0 babbles, 0 late collisions, 0 deferred
0 lost carrier, 0 no carrier
input queue (curr/max blocks): hardware (128/128) software (0/0)
output queue (curr/max blocks): hardware (0/0) software (0/0)
interface ethernet1 "inside" is up, line protocol is down
Hardware is i82559 ethernet, address is 0013.c365.defd
IP address 192.168.1.1, subnet mask 255.255.255.0
MTU 1500 bytes, BW 100000 Kbit full duplex
1 packets output, 60 bytes, 0 underruns
<--- More ---> output queue (curr/max blocks): hardware (0/1) software (0/1)
pix(config)#
