PIX 501 Switch Problem
andyleealbrecht
Community Member
My PIX 501 has been running like a champ for the last 6 months but today when I came home, all of the lights on the switch portion were off. The power light and the light for the 0 port were still lit up but none of the lights for the 1-4 ports were lit up. I haven't made any configuration changes, so I'm not sure why all of a sudden the switch portion would just up and quit. I've powered it off and that didn't make a difference. Any help or ideas would be appreciated. I'd be glad to provide any information needed. Thank you.
15 Replies 15
jdepies
Level 3
Level 3
if you plug in the console cable will it reboots, do any errors come up on the screen?
Thanks for the response! I tried setting it back to factory defaults a few minutes ago and when it boots up it now says "Cannot select private key" but it didn't say that before. Other than that, I don't see any errors on boot.
can you copy and paste the entire boot text from the console screen? That way we can see how far in the boot process it gets before it errors out.
The error message for the private is normal when the hostname or domainname does not fit with the ssh private key. You can simply create a new one and the message will disappear.
#To see the ss key:
show ca mypubkey rsa
#configure hostnmae and domainname:
hostname cisco-pix
domain-name example.com
#Remove old public key:
ca zeroize rsa key
#Generate a new ssh key:
ca generate rsa key 1024
#Verifiy again the ssh key:
Save the new ssh key:
ca save all
Allow incomming ssh connections:
ssh ip_address [netmask] [interface_name]
See whitepaper for this settings:
http://www.cisco.com/en/US/products/sw/secursw/ps2120/products_configuration_guide_chapter09186a0080172797.html#wp1034079
sincerely
Patrick
I followed the instructions provided by patrick.iseli and I was able to get rid of that private key error.(Thanks patrick) Here is what I captured during boot...Hopefully there is a way to resolve my switch problem. Thanks again!
Rebooting....
CISCO SYSTEMS PIX-501
Embedded BIOS Version 4.3.200 07/31/01 15:58:22.08
Compiled by morlee
16 MB RAM
PCI Device Table.
Bus Dev Func VendID DevID Class Irq
00 00 00 1022 3000 Host Bridge
00 11 00 8086 1209 Ethernet 9
00 12 00 8086 1209 Ethernet 10
Cisco Secure PIX Firewall BIOS (4.2) #6: Mon Aug 27 15:09:54 PDT 2001
Platform PIX-501
Flash=E28F640J3 @ 0x3000000
Use BREAK or ESC to interrupt flash boot.Use SPACE to begin flash boot immediately.Flash boot in 10
seconds. 9 seconds. 8 seconds. 7 seconds.6 seconds.5 seconds. 4 seconds. 3 seconds. 2 seconds. 1 seconds.
Reading 1962496 bytes of image from
flash.################################################################################################
16MB RAM
mcwa i82559 Ethernet at irq 9 MAC: 0013.c365.defb
mcwa i82559 Ethernet at irq 10 MAC: 0013.c365.defd
BIOS Flash=E28F640J3 @ 0xD8000
c i s c o S y s t e m s
Private Internet eXchange
Cisco PIX Firewall
Cisco PIX Firewall Version 6.3(4)
Licensed Features:
Failover: Disabled
VPN-DES: Enabled
VPN-3DES-AES: Enabled
Maximum Physical Interfaces: 2
Maximum Interfaces: 2
Cut-through Proxy: Enabled
Guards: Enabled
URL-filtering: Enabled
Inside Hosts: 10
Throughput: Unlimited
IKE peers: 10
This PIX has a Restricted (R) license.
****************************** Warning *******************************
Compliance with U.S. Export Laws and Regulations - Encryption.
This product performs encryption and is regulated for export
by the U.S. Government.
This product is not authorized for use by persons located
outside the United States and Canada that do not have prior
approval from Cisco Systems, Inc. or the U.S. Government.
This product may not be exported outside the U.S. and Canada
either by physical or electronic means without PRIOR approval
of Cisco Systems, Inc. or the U.S. Government.
Persons outside the U.S. and Canada may not re-export, resell
or transfer this product by either physical or electronic means
without prior approval of Cisco Systems, Inc. or the U.S.
Government.
******************************* Warning *******************************
Copyright (c) 1996-2003 by Cisco Systems, Inc.
Restricted Rights Legend
Use, duplication, or disclosure by the Government is
subject to restrictions as set forth in subparagraph
(c) of the Commercial Computer Software - Restricted
Rights clause at FAR sec. 52.227-19 and subparagraph
(c) (1) (ii) of the Rights in Technical Data and Computer
Software clause at DFARS sec. 252.227-7013.
Cisco Systems, Inc.
170 West Tasman Drive
San Jose, California 95134-1706
Cryptochecksum(unchanged): 4d7d25f4 e03f1452 ca1c82da 531641b5
Type help or '?' for a list of available commands.
pix>
I removed the doublicated message 😞
Just to do a recapulation of the status of your problem. Now everthing is working or do you still have an issue with your Switch ports ?
Note: That the power plug is not very reliable. You just move the power cable a little bit and the PIX 501 stops functioning correctly. I have seen this on some PIX 501 devices.
sincerely
Patrick
I'm still having problems with the switch ports. The PIX is getting power and the power light is lit. I can also use the console port and Port 0 will also work and light up, but none of the ports 1-4 appear to be working at all. Any help would be appreciated.
I'm assuming that without any good ports on the switch portion that this PIX 501 is now pretty much useless. Is this a correct assumption?
This sounds like a hardware issue, do you still have a garantie ?
This guides might help you to figure out the problem:
PIX Hardware Troubleshooting:
http://www.cisco.com/en/US/products/hw/vpndevc/ps2030/products_tech_note09186a0080094fd9.shtml
Hardware Troubleshooting Index Page:
http://www.cisco.com/en/US/products/hw/routers/ps214/products_tech_note09186a008012fb88.shtml
All PIX papers:
http://www.cisco.com/en/US/products/hw/vpndevc/ps2030/tsd_products_support_series_home.html
sincerely
Patrick
Unfortunately, this PIX was purchased on Ebay... which I assume leaves me with no way of getting support on the product.
Not sure if this applies, or why it would suddenly change, but looking at your running-config, is the Inside interface now set to "shutdown"? If not, I would concur that you have a hardware issue.
Here's the info returned when I run 'show conf'
show conf
Saved
Written by enable_15 at 20:34:53.129 UTC Tue Nov 1 2005
PIX Version 6.3(4)
interface ethernet0 auto
interface ethernet1 100full
nameif ethernet0 outside security0
nameif ethernet1 inside security100
enable password N7FecZuSHJlVZC2P encrypted
passwd 2KFQnbNIdI.2KYOU encrypted
hostname pix
domain-name ciscopix.local
fixup protocol dns maximum-length 512
fixup protocol ftp 21
fixup protocol h323 h225 1720
fixup protocol h323 ras 1718-1719
fixup protocol http 80
fixup protocol rsh 514
fixup protocol rtsp 554
fixup protocol sip 5060
fixup protocol sip udp 5060
fixup protocol skinny 2000
fixup protocol smtp 25
fixup protocol sqlnet 1521
fixup protocol tftp 69
<--- More ---> names
pager lines 24
mtu outside 1500
mtu inside 1500
no ip address outside
ip address inside 192.168.1.1 255.255.255.0
ip audit info action alarm
ip audit attack action alarm
pdm history enable
arp timeout 14400
timeout xlate 3:00:00
timeout conn 1:00:00 half-closed 0:10:00 udp 0:02:00 rpc 0:10:00 h225 1:00:00
timeout h323 0:05:00 mgcp 0:05:00 sip 0:30:00 sip_media 0:02:00
timeout uauth 0:05:00 absolute
aaa-server TACACS+ protocol tacacs+
aaa-server TACACS+ max-failed-attempts 3
aaa-server TACACS+ deadtime 10
aaa-server RADIUS protocol radius
aaa-server RADIUS max-failed-attempts 3
aaa-server RADIUS deadtime 10
aaa-server LOCAL protocol local
no snmp-server location
no snmp-server contact
snmp-server community public
<--- More ---> no snmp-server enable traps
floodguard enable
telnet timeout 5
ssh timeout 5
console timeout 0
terminal width 80
Cryptochecksum:4d7d25f4e03f1452ca1c82da531641b5
pix(config)#
Wow does the show interface looks like ?
show interface
sincerely
Patrick
