pix 515 problem urgently
cychenyan
hi,
I have a pix 515 with 3 interfaces, the outside interface and the DMZ interface are different subnets of one main net, which means that I have a legal net ( 200.200.200.0/26, the outside interface and the DMZ interface are 200.200.200.0/27 and 200.200.200.32/27, all the www and mail servers are located in the DMZ. One Router is outside of the PIX.
I have add the routes on the router to the DMZ net.
The problem is from the inside I can reach anywhere which I certainly use the nat, but from the DMZ I can not reach anywhere.
the configuration is below:
PIX Version 6.1(1)
nameif ethernet0 outside security0
nameif ethernet1 inside security100
nameif ethernet2 dmz security10
enable password xxxx encrypted
passwd xxxxx encrypted
hostname pixfirewall
fixup protocol ftp 21
fixup protocol http 80
fixup protocol h323 1720
fixup protocol rsh 514
fixup protocol rtsp 554
fixup protocol smtp 25
fixup protocol sqlnet 1521
fixup protocol sip 5060
fixup protocol skinny 2000
names
access-list 101 permit icmp any any
access-list 101 permit tcp any host 200.200.200.1 eq domain
access-list 101 permit udp any host 200.200.200.1 eq domain
access-list 101 permit tcp any host 200.200.200.6 eq www
access-list 101 permit tcp any host 200.200.200.8 eq ftp
access-list 101 permit tcp any host 200.200.200.3 eq smtp
access-list 101 permit ip any any
access-list 102 permit ip any any
pager lines 24
interface ethernet0 auto
interface ethernet1 auto
interface ethernet2 auto
mtu outside 1500
mtu inside 1500
mtu dmz 1500
ip address outside xxxx.xxx.xxx.59 255.255.255.224
ip address inside xxx.xxx.xx.230 255.255.255.0
ip address dmz 200.200.200.30 255.255.255.224
ip audit info action alarm
ip audit attack action alarm
pdm history enable
arp timeout 60
global (outside) 1 200.200.200.61
global (dmz) 1 200.200.200.15
nat (inside) 1 0.0.0.0 0.0.0.0 0 0
access-group 101 in interface outside
access-group 102 in interface dmz
route outside 0.0.0.0 0.0.0.0 200.200.200.62 1
route inside 192.168.10.0 255.255.255.0 192.168.30.1 1
route inside 192.168.20.0 255.255.255.0 192.168.30.1 1
timeout xlate 3:00:00
timeout conn 1:00:00 half-closed 0:10:00 udp 0:02:00 rpc 0:10:00 h323 0:05:00 sip 0:30:00 sip_media 0:02:00
timeout uauth 0:05:00 absolute
aaa-server TACACS+ protocol tacacs+
aaa-server RADIUS protocol radius
no snmp-server location
no snmp-server contact
snmp-server community public
no snmp-server enable traps
floodguard enable
no sysopt route dnat
telnet timeout 5
ssh timeout 5
terminal width 80
Cryptochecksum:xxxxxxx
: end
[OK]
bdube
Level 2
Level 2
you need the following static & nat commands:
static (dmz,outside) 200.200.200.1 200.200.200.1 netmask 255.255.255.255
static (dmz,outside) 200.200.200.3 200.200.200.3 netmask 255.255.255.255
static (dmz,outside) 200.200.200.6 200.200.200.6 netmask 255.255.255.255
static (dmz,outside) 200.200.200.8 200.200.200.8 netmask 255.255.255.255
And for DMZ to go out:
nat (dmz) 1 0.0.0.0 0.0.0.0
Ben
I agree with this solution but I don't understand access-list 101
access-list 101 permit ip any any <-------------------------------------------------
I think the last statement should be: deny ip any any
Aad
THis is an implicit rule that happens automatically. You only need it if you want to log the deny alls, otherwise it won't get logged
I agree with Aad (good to see you here Aad *grin*)
The permit ip any any will drill a serious securityhole in your PIX. Your PIX is open to any traffic with this command (not implicit command like the other guy stated, cause the implicit rule depending on securitylevels is never seen in config)
If you do not want the servers on the dmz to be reachable from the outside, the nat (dmz) 1 0.0.0.0 0.0.0.0 will do
The static commands provides you with the ability to let the PIX proxy-ARP on the outside interface for these adresses (no further config needed)
Kind Regards,
Leo
K
