pix 515E 7.21 logging enable problem.
chieh-min-hsieh
i have a pix 515E(UR), WITH 128MB RAM,16MB FLASH.
I Upgrade os to 7.21 with ASDM5.21 Version.
but i got a problem.
if i enable logging function.
the cpu usage will rise to 96%
if i disable it. it back to 3~10%. its never happen when i use 6.3(3) and PDM3.0 ,i used to cache the syslog message it shows as blow
Local4.Info 192.168.51.253 %PIX-6-302020: Built ICMP connection for faddr kk/0 gaddr 192.168.51.253/0 laddr 192.168.51.253/0
Local4.Info 192.168.51.253 %PIX-6-302021: Teardown ICMP connection for faddr kk/0 gaddr 192.168.51.253/0 laddr 192.168.51.253/0
"kk"is my syslog and asdm server.
192.168.51.253 is inside interface ip address.
where's the problem?
thanks for help!!
spremkumar
Level 9
Level 9
Can you configure your pix to login information pertaining to specific levels ?
You can do the same using the command logging level 4 which will log all the logs related to message level 0 to 4 ..
http://www.cisco.com/en/US/products/sw/secursw/ps2120/products_command_reference_chapter09186a00801727a9.html#wp1028090
regds
alanajjar
I have an idea , but dont know if it will work. the idea is to increase the timeout on the pix using the command
sysopt connection timeout
with regadrs
ala al najjar
