pix 515E 7.21 logging enable problem.
chieh-min-hsieh
Community Member
i have a pix 515E(UR), WITH 128MB RAM,16MB FLASH.
I Upgrade os to 7.21 with ASDM5.21 Version.
but i got a problem.
if i enable logging function.
the cpu usage will rise to 96%
if i disable it. it back to 3~10%. its never happen when i use 6.3(3) and PDM3.0 ,i used to cache the syslog message it shows as blow
Local4.Info 192.168.51.253 %PIX-6-302020: Built ICMP connection for faddr kk/0 gaddr 192.168.51.253/0 laddr 192.168.51.253/0
Local4.Info 192.168.51.253 %PIX-6-302021: Teardown ICMP connection for faddr kk/0 gaddr 192.168.51.253/0 laddr 192.168.51.253/0
"kk"is my syslog and asdm server.
192.168.51.253 is inside interface ip address.
where's the problem?
thanks for help!!
spremkumar
Level 11
Level 11
Can you configure your pix to login information pertaining to specific levels ?
You can do the same using the command logging level 4 which will log all the logs related to message level 0 to 4 ..
http://www.cisco.com/en/US/products/sw/secursw/ps2120/products_command_reference_chapter09186a00801727a9.html#wp1028090
regds
alanajjar
Level 3
Level 3
I have an idea , but dont know if it will work. the idea is to increase the timeout on the pix using the command
sysopt connection timeout
with regadrs
ala al najjar
