Pix 515e Interface Card Problem
Phoungsakdavin
Level 2
Level 2
Normally, they use only two ports as External and Internal Interfaces. Now they are using PIX-4FE-66 to get extra 4 interfaces card for Servers Farm.
The problem is the new 4 interfaces do not function or work properly. We cannot access or ping to the Servers even ping to the 4 Interfaces. Meaning that I cannot ping from the PC in the Internal interface to its gateway (Ethernet2, 3, 4, 5), but Ethernet0, 1.
I have noticed that when I do a ping from Internal PC to Ethernet 0, 1, and add debug icmp trace command, I got the reply message in the pix, but if I ping to the 4 interfaces, no debug message appear. But when I show interface, I see the packets input is increased in each interface.
Note: I have installed the card to my new Pix 515e for testing, but still get the same problem.
I would appreciated with any feedback and solutions.
VIN
a.kiprawih
Level 11
Level 11
Just a quick check... is your 515E running UR license?
Have you enable all 4 interfaces? Can you ping (from PIX itself) ip addresses assigned to the interfaces?
rgds
AK
Yes, The Pix 515E is running UR license. The 4 interfaces have been eable as shown in the attached file. I also can ping from Pix itself to every Pix's interfaces. But I can also ping from my pc to Built-in interface(Ethernet0,Ethernet1), but the 4 interfaces card)
VIN
