PIX 520 Failover... How does it work?
mowtnman
Level 2
Level 2
I know that when using HSRP for routers and switches that the HSRP that will use a virtual IP and MAC address that it uses in case of hardware failure.
With a PIX 520 how exactly does he failover work?
Is it similar to the way HSRP functions-i.e. virtual IP and MAC... or ???
Any comments are appreciated
jose.calvillo
Community Member
Please see the following link, it discusses everything concerning PIX failover.
http://www.cisco.com/univercd/cc/td/doc/product/iaabu/pix/pix_61/config/failover.htm
Thanks- this helps clerify.
pmoulay
Community Member
http://www.cisco.com/univercd/cc/td/doc/product/iaabu/pix/pix_v50/config/advanced.htm
You are correct in your comments. Still the Hello protocol working behind the scenes. From a practical point of view, all the failover configuration is done on the primary unit. No need to physically be on the second unit. Make sure you have an extra IP addres for the failover unit. USe the failover ip address command for the different interfaces.
