Pix hardware booting problem
elnurh
Level 3
Level 3
Hi everybody.Can anyony help to undestand what is that message. My pix firewall booting not complete.
In the screen to appear this message:
CISCO SYSTEMS PIX FIREWALL
Embedded BIOS Version 4.3.207 01/02/02 16:12:22.73
Compiled by morlee
32 MB RAM
PCI Device Table.
Bus Dev Func VendID DevID Class Irq
00 00 00 8086 7192 Host Bridge
00 07 00 8086 7110 ISA Bridge
00 07 01 8086 7111 IDE Controller
00 07 02 8086 7112 Serial Bus 9
00 07 03 8086 7113 PCI Bridge
00 0D 00 8086 1209 Ethernet 11
00 0E 00 8086 1209 Ethernet 10
and then pix stop booting and this message freeze in the screen.
May be anyone know this problem ?
Thannks before
6 Replies 6
bphan
Level 4
Level 4
Hello there:
What PIX model and software version do you have?
Binh
Version this pix :Cisco PIX Firewall Version 6.2(2)
model pix 506E
Nobody can help me to resolve this ploblem ?
Hi there,
You can try loading PIX 6.3.4 code under Monitor mode as described in this document:
http://www.cisco.com/en/US/products/hw/vpndevc/ps2030/products_tech_note09186a0080094a5d.shtml
PIX 6.3.4 code can be picked up at the following site:
http://www.cisco.com/cgi-bin/tablebuild.pl/pix
Login with CCO userid/password.
Let me know how it turns out after loading a new image.
Binh
thanks for helping but you know it's problem is not first time. When this happen first time I am reset bios change the jack in the motherboard and when pix normal booting I was upgrade version pix 6.3.(3). But problem not resolving.
Tell me please may be is motherboard problem, bios,
I don't know exactly but I think it's hardware ploblem not software what do you think about ?
Hi:
At this point, i would say to go ahead and open a TAC case and have the unit RMA'd.
Binh
