PIX525 - Policy NAT, problem with two outside interfaces
anton_lva
Hi all!
I have PIX with two virtual outside, inside and dmz interfaces.
Outside 1: outside-205 - 195.1.1.10/24
Outside 2: outside-500 - 220.2.2.20/24
inside - 192.168.3.0/24
dmz - 192.168.4.0/24
My task is to translate inside hosts to 195.1.1.10 and dmz hosts - to 220.2.2.20 (using PAT).
Inside hosts are translated correctly, but dmz translation fails with error
PIX-3-305006: portmap translation creation failed for icmp src dmz:192.168.4.x dst outside-205:x.x.x.x (type 8, code 0)
Here is my configuration:
=== 8< ===
PIX Version 7.2(2)
interface Ethernet0.10
vlan 205
nameif outside-205
security-level 0
ip address 195.1.1.10 255.255.255.248
interface Ethernet0.500
vlan 500
nameif outside-500
security-level 0
ip address 220.2.2.20 255.255.255.248
interface Ethernet1
no nameif
no security-level
no ip address
interface Ethernet1.20
vlan 20
nameif inside
security-level 100
ip address 192.168.3.254 255.255.255.0
interface Ethernet1.30
vlan 30
nameif dmz
security-level 50
ip address 192.168.4.254 255.255.255.0
same-security-traffic permit inter-interface
same-security-traffic permit intra-interface
access-list INSIDE-TO-NAT extended permit ip 192.168.3.0 255.255.255.0 any
access-list DMZ-TO-NAT extended permit ip 192.168.4.0 255.255.255.0 any
nat-control
global (outside-205) 1 interface
global (outside-500) 2 interface
nat (inside) 1 access-list INSIDE-TO-NAT
nat (dmz) 2 access-list DMZ-TO-NAT
route outside-205 0.0.0.0 0.0.0.0 195.1.1.1 1
route outside-500 0.0.0.0 0.0.0.0 220.2.2.2 2
=== 8< ===
What am I doing wrong?
Thanks!
Fernando_Meza
Level 11
Level 11
Hi .. your configuration is OK the problem is caused because any packets to the Internet are routed by interface outside-205 .. Inside hosts go out OK because there is a nat-global pair for this access applied to the outside-205 interface, however the hosts on the dmz don't have a global applied to the outside-205 interface only to the outside-500 interface which will only be used when the outside-205 is down. The same issue will happened with the inside hosts when outside-500 is up and outside-205 is down
you could add as below to get this working
global (outside-205) 2
I hope it helps .. please rate it if it does
Thanks, Fernando, I’ve added
"global (outside-205) 2 220.2.2.2"
to my configuration, and it really helped to get rid of message "portmap translation failed".
But... The problem still exists.
For example, when I try to connect to some external www-server from the host in dmz, I have the next error:
PIX-7-710005: TCP request discarded from x.x.x.x/80 to outside-500:220.2.2.2/1035
How I can understand, PIX doesn't have a valid translation entry for interface outside-500 (but does for outside-205?) and doesn't expect reply from the remote www-server?
Here is a part of my translations table by "show xlate detail":
TCP PAT from dmz:192.168.4.x/32990 to outside-205(DMZ-TO-NAT):220.2.2.2/1035 flags ri
Do I need to add some static entries or additional access-lists?
Thanks in advance!
Hmm... The problem still exists.
I've tried everything, but it doesn't help!
Someone, please, help me!
