Port channel problem on FDM 7.0.0-94 version
SadiImanov3543
On firepower 1140, I can't setup port-channel between sfp ports. FDM version was 6.4.0 I upgraded it to 7.0.0-94. On both versions it doesn't work.
How I can solve it. I need very urgent solution on that.
Thank you for your support
BIbrahimov
Dear Sadi,
I have faced with the same issue. Port channel is not available on 6.4 version. It was added on 6.6 version. Today recommended version is 6.6.x. In my opinion if you will downgrade until 6.6 it must work. Please check this solution.
Hope I could help you.
Thank you
Marvin Rhoads
Prior to adding an interface to an Etherchannel it must be unconfigured (no nameif, IP address etc.)
