Port Forward Dropped by nat (inside,outside) dynamic interface
EasyGoing1
Been frustrated with this all day ... here is my config:
: Saved
ASA Version 9.2(4)
hostname ciscoasa
names
interface Ethernet0/0
 switchport access vlan 2
interface Ethernet0/1
interface Ethernet0/2
interface Ethernet0/3
interface Ethernet0/4
interface Ethernet0/5
interface Ethernet0/6
interface Ethernet0/7
interface Vlan1
 nameif inside
 security-level 100
 ip address 10.10.10.1 255.255.255.0
interface Vlan2
 nameif outside
 security-level 0
 ip address dhcp setroute
ftp mode passive
clock timezone PST -8
clock summer-time DST recurring 3 Sun Mar 2:00 2 Sun Nov 2:00
object network insideNet
 subnet 10.10.10.0 255.255.255.0
object network Mike
 host 10.10.10.90
access-list inbound extended permit udp any host 10.10.10.90
access-list inbound extended permit tcp any host 10.10.10.90
pager lines 24
logging asdm informational
mtu outside 1500
mtu inside 1500
icmp unreachable rate-limit 1 burst-size 1
no asdm history enable
arp timeout 14400
no arp permit-nonconnected
object network Mike
 nat (outside,inside) static interface service udp 5800 5800
access-group inbound in interface outside
timeout xlate 3:00:00
timeout pat-xlate 0:00:30
timeout conn 1:00:00 half-closed 0:10:00 udp 0:02:00 icmp 0:00:02
timeout sunrpc 0:10:00 h323 0:05:00 h225 1:00:00 mgcp 0:05:00 mgcp-pat 0:05:00
timeout sip 0:30:00 sip_media 0:02:00 sip-invite 0:03:00 sip-disconnect 0:02:00
timeout sip-provisional-media 0:02:00 uauth 0:05:00 absolute
timeout tcp-proxy-reassembly 0:01:00
timeout floating-conn 0:00:00
dynamic-access-policy-record DfltAccessPolicy
user-identity default-domain LOCAL
aaa authentication ssh console LOCAL
http server enable
http 10.10.10.0 255.255.255.0 inside
no snmp-server location
no snmp-server contact
crypto ipsec security-association pmtu-aging infinite
crypto ca trustpool policy
telnet timeout 5
no ssh stricthostkeycheck
ssh 10.10.10.0 255.255.255.0 inside
ssh timeout 60
ssh key-exchange group dh-group1-sha1
console timeout 0
dhcpd auto_config outside
dhcpd address 10.10.10.5-10.10.10.36 inside
dhcpd dns 1.1.1.1 8.8.8.8 interface inside
dhcpd enable inside
threat-detection basic-threat
threat-detection statistics access-list
no threat-detection statistics tcp-intercept
ntp server 216.239.35.4 prefer
ntp server 216.239.35.8
ntp server 216.239.35.12
username michael ...... privilege 15
class-map inspection_default
 match default-inspection-traffic
policy-map type inspect dns preset_dns_map
 parameters
  message-length maximum client auto
  message-length maximum 512
policy-map global_policy
 class inspection_default
  inspect ftp
  inspect h323 h225
  inspect h323 ras
  inspect rsh
  inspect rtsp
  inspect esmtp
  inspect sqlnet
  inspect skinny
  inspect sunrpc
  inspect xdmcp
  inspect sip
  inspect netbios
  inspect tftp
  inspect ip-options
  inspect icmp
service-policy global_policy global
prompt hostname context
no call-home reporting anonymous
: end
Here is the output of this command: packet-tracer input outside udp 13.57.212.236 5800 10.10.10.90 5800
ciscoasa(config)# packet-tracer input outside udp 13.57.212.236 5800 10.10.$
Phase: 1
Type: ACCESS-LIST
Subtype:
Result: ALLOW
Config:
Implicit Rule
Additional Information:
MAC Access list
Phase: 2
Type: ROUTE-LOOKUP
Subtype: Resolve Egress Interface
Result: ALLOW
Config:
in   10.10.10.0      255.255.255.0   inside
Phase: 3
Type: ACCESS-LIST
Subtype: log
Result: ALLOW
Config:
Phase: 4
Type: NAT
Subtype: per-session
Result: ALLOW
Config:
Phase: 5
Type: IP-OPTIONS
Subtype:
Result: ALLOW
Config:
Phase: 6
Type: HOST-LIMIT
Subtype:
Result: ALLOW
Config:
Phase: 7
Type: NAT
Subtype: rpf-check
Result: DROP
Config:
Result:
input-interface: outside
input-status: up
input-line-status: up
output-interface: inside
output-status: up
output-line-status: up
Action: drop
Drop-reason: (acl-drop) Flow is denied by configured rule
Notice that it is the rule that lets me get out that is for some reason denying the inbound traffic.... I don't understand how to fix this...
Mike Sims
guess this will help you bit.
https://itknowledgeexchange.techtarget.com/network-technologies/error-rpf-check-result-drop-cisco-asa-packet-tracer/
regards,
Good luck
KB
Sheraz.Salim
now if you want port forward this above command is not going to work.
as you doing NAT one to many.
object network Mike
change this
object network Mike
 nat (inside,outside) static interface server udp 5800 5800
and than do a packet tracer.
please do not forget to rate.
