Port forwarding - Cisco ASA5505 - Running ASA 9.1(2) - ADSM 7.1(3)
pavi
Hi!
I have a few issues configuring the right stuff for this asa with the software mentioned above.
This is what i need done...
1. OpenVPN (port 1194 - UDP) - Open from outside to inside and back. - The OpenVPN server is connected to a NAS-server on a 192.168.10.xxx adress
2. I have problems sending out mails from a server on the inside using either port 25 or port 587.. The asa won't let the traffic pass from inside to outside.
3. Last config looking for..   I have placed a FTP-server on the inside running on port 31030. how do i get it up and running from the outside to reach it..
If you guys can help me out with the config for these thru the ASDM - It would be great , but thru CLI is fine aswell..  As long as i can get those things running - i would be really happy.. ;-)
Looking forward to hear from you guys..
2 Accepted Solutions
Marvin Rhoads
Is this a brand new configuration? Your questions imply that it is.
Usually (but not always) you need a NAT for inside traffic to the outside. Do you have only the single public IP on the outside or do you have a subnet to work with? This bounds your options in setting up NAT entries and how to allow the things you asked about. If you can post the configuration file that would be helpful in answering your questions better.
1. Simply add an access-list entry on the outside interface. Source any, destination real IP and port 1194 of your server (which may be associated with either a static or dynamic NAT entry).
2. The NAT needs to be in place for this to work. Once it is, and assuming no access-list on the inbound interface and that a route exists to the destination, traffic is allowed by default from high security (inside) to lower security zones (outside).
3. Same approach as #1 above.
Sometimes the ASA's smtp inspection actions break email. You can try:
class inspection_default
no inspect esmtp
...to turn it off.
10 Replies 10
Marvin Rhoads
Hi Marvin,
Is it possible for you to do the lines i have to put in thru the CLI-interface..   I tried a dozen of different ways but i don't seem to be able to do it..  Pretty new to this box - So trying to learn. hehe..   Here is my config file - Pretty clean as for now..  Simple config - Building it up step by step..
Please let me know how to get those three requests working with the cli-commands i have to do..  if it ain't to much work.. hehe ..  Thanks alot..  AND YES - Only one public IP to work with..  ;-)
Config file currently :
: Written by enable_15 at 21:50:51.749 UTC Sat Jul 6 2013
ASA Version 9.1(2)
hostname asa
domain-name asa
enable password XX encrypted
xlate per-session deny tcp any4 any4
xlate per-session deny tcp any4 any6
xlate per-session deny tcp any6 any4
xlate per-session deny tcp any6 any6
xlate per-session deny udp any4 any4 eq domain
xlate per-session deny udp any4 any6 eq domain
xlate per-session deny udp any6 any4 eq domain
xlate per-session deny udp any6 any6 eq domain
passwd XX encrypted
names
interface Ethernet0/0
switchport access vlan 2
interface Ethernet0/1
interface Ethernet0/2
interface Ethernet0/3
interface Ethernet0/4
interface Ethernet0/5
switchport access vlan 12
switchport protected
interface Ethernet0/6
interface Ethernet0/7
interface Vlan1
nameif inside
security-level 100
ip address 192.168.10.1 255.255.255.0
interface Vlan2
nameif outside
security-level 0
ip address dhcp setroute
interface Vlan12
nameif DMZ
security-level 50
ip address 192.168.2.1 255.255.255.0
boot system disk0:/asa912-k8.bin
ftp mode passive
dns server-group DefaultDNS
domain-name asa
object network obj_any
subnet 0.0.0.0 0.0.0.0
object network Work
host 192.168.2.10
pager lines 24
logging enable
logging asdm informational
mtu inside 1500
mtu outside 1500
mtu DMZ 1500
no failover
icmp unreachable rate-limit 1 burst-size 1
asdm image disk0:/asdm-713.bin
no asdm history enable
arp timeout 14400
no arp permit-nonconnected
nat (inside,outside) dynamic interface
object network Work
nat (any,outside) static interface
timeout xlate 3:00:00
timeout pat-xlate 0:00:30
timeout conn 1:00:00 half-closed 0:10:00 udp 0:02:00 icmp 0:00:02
timeout sunrpc 0:10:00 h323 0:05:00 h225 1:00:00 mgcp 0:05:00 mgcp-pat 0:05:00
timeout sip 0:30:00 sip_media 0:02:00 sip-invite 0:03:00 sip-disconnect 0:02:00
timeout sip-provisional-media 0:02:00 uauth 0:05:00 absolute
timeout tcp-proxy-reassembly 0:01:00
timeout floating-conn 0:00:00
dynamic-access-policy-record DfltAccessPolicy
user-identity default-domain LOCAL
aaa authentication ssh console LOCAL
http server enable
http 192.168.10.0 255.255.255.0 inside
no snmp-server location
no snmp-server contact
snmp-server enable traps snmp authentication linkup linkdown coldstart warmstart
crypto ipsec security-association pmtu-aging infinite
crypto ca trustpoint ASDM_TrustPoint0
enrollment self
subject-name CN=brainbox
keypair
crl configure
crypto ca trustpool policy
telnet timeout 5
ssh 192.168.10.0 255.255.255.0 inside
ssh timeout 5
ssh key-exchange group dh-group1-sha1
console timeout 0
dhcpd auto_config outside
dhcpd address 192.168.10.10-192.168.10.30 inside
dhcpd auto_config outside interface inside
dhcpd enable inside
threat-detection basic-threat
threat-detection statistics access-list
no threat-detection statistics tcp-intercept
webvpn
anyconnect-essentials
username pascal password XX encrypted privilege 15
class-map inspection_default
match default-inspection-traffic
policy-map type inspect dns preset_dns_map
parameters
  message-length maximum client auto
  message-length maximum 512
policy-map global_policy
  inspect ftp
  inspect h323 h225
  inspect h323 ras
  inspect rsh
  inspect rtsp
  inspect esmtp
  inspect sqlnet
  inspect skinny
  inspect sunrpc
  inspect xdmcp
  inspect sip
  inspect netbios
  inspect tftp
  inspect ip-options
  inspect icmp
  inspect icmp error
service-policy global_policy global
prompt hostname context
no call-home reporting anonymous
Cryptochecksum:XX
Something like this:
asa# conf t
asa(config)# object network host OpenVPN_Server
asa(config-network-object)# nat (inside, outside) dynamic 192.168.10.xxx service tcp 1194
asa(config-network-object)# object network host FTP_Server
asa(config-network-object)# nat (inside, outside) dynamic service tcp 31030
asa(config)# exit
asa(config)# access-list outside_access permit tcp any host OpenVPN_Server eq 1194
asa(config)# access-list outside_access permit tcp any host FTP_Server eq 31030
asa(config)# access-group outside_access interface outside
asa(config)exit
I'm not sure why your outbound email isn't working already. Are you getting a good interface address and default route on the ASA from the outside DHCP server?
Thanks for the above..  I will try it out right away and see if it works out..   I appricate your time in this.
In regards to the email..  Its my Synology-server that comes up with an error trying to send an email..  I have set it up to send mesages thru gmail for warnings etc..   It used to work on a different firewall without any settings..  But hasn't worked after installing this one..  So for me it sounds like that it won't let me send email from those ports without rules created in the box ??     I will look into the log an see what error it comes up with and copy/paste it here..
Thanks so far for the info above - I will try it out and let you know if it fixed it..
/pascal
no inspect esmtp
...to turn it off.
Hey Marvin,
The email-part worked perfectly..   I can now send emails thru it.. PERFECT !!! thanks for fixing that one..
But the other part..   Didnt work out.. it comes with errors..  Look below :
Already at the first part it goes wrong..
brainbox# config t
brainbox(config)# object network host OpenVPN_Server
ERROR: % Invalid input detected at '^' marker.
brainbox(config)#
So i believe before that one is created - The next line won't make any sense...
nat (inside, outside) dynamic 192.168.10.xxx service tcp 1194 <-----------
Uhmm.. does this make sense to you .. what is wrong?
Great that the mail is working.
I think my syntax was a bit off - it should be object-network etc. But you might be better off trying the GUI for setting up a public server for your two public servers. The configuration guide section here should help:
http://www.cisco.com/en/US/docs/security/asa/asa91/asdm71/firewall/access_public_servers.html#wp1091646
Hi Marvin,
Tried to follow the guide - But still not home free..  I'm just thinking...  How hard can it really be to make OpenVPN on port 1194 working..   Thats the only port for OpenVPN that needs access thru my firewall and i can't seem to figure out how to configure it correctly.
Anyone in the forum here that has a Synology like i do and knows how to get this working ?
I appriciate your tryings Marvin..   ;-)
Uhmm.. it says " Question is answered" - Not 100 percent..  Please read above this post..    I still need assistance...    Thanks...
Pascal,
Did you get the "object-network host" command with its associated nat and access-list entries to take? If you could post the updated configuration with that in place, we can have a look at it some more.
- Marvin
