Port Forwarding Help!!
livingdeadbeat
Community Member
After banging my head on my keyboard for about 3 days straight now I have to ask for help. I am trying to forward specific ports from the outside interface on my ASA5505 to my servers inside and can not get it to work! I have a VPN that currently works and the firewall rule in place I am just overlooking something simple I'm sure. Here is the config:
ASA Version 8.2(5)
hostname ASA
enable password <removed>
passwd <removed>
names
name 172.20.2.4 DC
name 172.20.2.7 VP
name 172.20.2.24 AP
interface Ethernet0/0
switchport access vlan 2
interface Ethernet0/1
interface Ethernet0/2
interface Ethernet0/3
shutdown
interface Ethernet0/4
shutdown
interface Ethernet0/5
shutdown
interface Ethernet0/6
shutdown
interface Ethernet0/7
shutdown
interface Vlan1
nameif inside
security-level 100
ip address 172.20.0.3 255.255.0.0
interface Vlan2
nameif outside
security-level 0
ip address <Public-IP> 255.255.255.252
ftp mode passive
access-list inside_nat0_outbound extended permit ip any 172.20.22.0 255.255.255.192
access-list outside_access_in extended permit tcp any host <Public-IP>eq 2332
access-list outside_access_in extended permit tcp any host <Public-IP>eq 5901
access-list outside_access_in extended permit tcp any host <Public-IP>eq 5500
access-list outside_access_in extended permit tcp any host <Public-IP>eq 5705
access-list outside_access_in extended permit tcp any host <Public-IP>eq 81
pager lines 24
mtu inside 1500
mtu outside 1500
ip local pool VPN-IP-Pool 172.20.22.1-172.20.22.55 mask 255.255.0.0
icmp unreachable rate-limit 1 burst-size 1
no asdm history enable
arp timeout 14400
nat-control
global (outside) 1 interface
nat (inside) 0 access-list inside_nat0_outbound
nat (inside) 1 172.20.0.0 255.255.0.0
static (inside,outside) tcp interface 2332 VP 2332 netmask 255.255.255.255
static (inside,outside) tcp interface 5901 VP 5901 netmask 255.255.255.255
static (inside,outside) tcp interface 5500 VP 5500 netmask 255.255.255.255
static (inside,outside) tcp interface 5705 AP 5705 netmask 255.255.255.255
static (inside,outside) tcp interface 81 AP 81 netmask 255.255.255.255
access-group outside_access_in in interface outside
route outside 0.0.0.0 0.0.0.0 X.X.X.X 1
timeout xlate 3:00:00
timeout conn 1:00:00 half-closed 0:10:00 udp 0:02:00 icmp 0:00:02
timeout sunrpc 0:10:00 h323 0:05:00 h225 1:00:00 mgcp 0:05:00 mgcp-pat 0:05:00
timeout sip 0:30:00 sip_media 0:02:00 sip-invite 0:03:00 sip-disconnect 0:02:00
timeout sip-provisional-media 0:02:00 uauth 0:05:00 absolute
timeout tcp-proxy-reassembly 0:01:00
timeout floating-conn 0:00:00
dynamic-access-policy-record DfltAccessPolicy
aaa-server Radius protocol radius
aaa-server Radius (inside) host 172.20.0.3
timeout 5
key *****
aaa-server Radius (inside) host DC
timeout 5
key *****
aaa authentication ssh console LOCAL
aaa authentication http console LOCAL
aaa authentication telnet console LOCAL
http server enable
http 172.20.0.0 255.255.0.0 inside
no snmp-server location
no snmp-server contact
snmp-server enable traps snmp authentication linkup linkdown coldstart
crypto ipsec transform-set ESP-AES-256-MD5 esp-aes-256 esp-md5-hmac
crypto ipsec transform-set ESP-DES-SHA esp-des esp-sha-hmac
crypto ipsec transform-set ESP-3DES-SHA esp-3des esp-sha-hmac
crypto ipsec transform-set ESP-DES-MD5 esp-des esp-md5-hmac
crypto ipsec transform-set ESP-AES-192-MD5 esp-aes-192 esp-md5-hmac
crypto ipsec transform-set ESP-3DES-MD5 esp-3des esp-md5-hmac
crypto ipsec transform-set ESP-AES-256-SHA esp-aes-256 esp-sha-hmac
crypto ipsec transform-set ESP-AES-128-SHA esp-aes esp-sha-hmac
crypto ipsec transform-set ESP-AES-192-SHA esp-aes-192 esp-sha-hmac
crypto ipsec transform-set ESP-AES-128-MD5 esp-aes esp-md5-hmac
crypto ipsec transform-set VPN esp-des esp-sha-hmac
crypto ipsec transform-set VPN mode transport
crypto ipsec transform-set TRANS_ESP_3DES_SHA esp-3des esp-sha-hmac
crypto ipsec transform-set TRANS_ESP_3DES_SHA mode transport
crypto ipsec transform-set l2tp-transform esp-3des esp-sha-hmac
crypto ipsec transform-set l2tp-transform mode transport
crypto ipsec transform-set vpn-transform esp-aes-256 esp-sha-hmac
crypto ipsec security-association lifetime seconds 28800
crypto ipsec security-association lifetime kilobytes 4608000
crypto dynamic-map SYSTEM_DEFAULT_CRYPTO_MAP 65535 set pfs group1
crypto dynamic-map SYSTEM_DEFAULT_CRYPTO_MAP 65535 set transform-set ESP-AES-128-SHA ESP-AES-128-MD5 ESP-AES-192-SHA ESP-AES-192-MD5 ESP-AES-256-SHA ESP-AES-256-MD5 ESP-3DES-SHA ESP-3DES-MD5 ESP-DES-SHA ESP-DES-MD5
crypto dynamic-map dyn-map 10 set transform-set l2tp-transform vpn-transform
crypto dynamic-map dyn-map 10 set reverse-route
crypto map outside_map 65535 ipsec-isakmp dynamic SYSTEM_DEFAULT_CRYPTO_MAP
crypto map vpn-map 10 ipsec-isakmp dynamic dyn-map
crypto map vpn-map interface outside
crypto isakmp enable outside
crypto isakmp policy 10
authentication pre-share
encryption 3des
hash sha
group 2
lifetime 28800
crypto isakmp policy 15
encryption aes-256
hash sha
group 2
lifetime 86400
crypto isakmp policy 30
encryption 3des
hash sha
group 2
lifetime 86400
crypto isakmp policy 50
authentication crack
encryption 3des
hash sha
group 2
lifetime 86400
crypto isakmp policy 65535
encryption 3des
hash sha
group 2
lifetime 86400
telnet 172.20.0.0 255.255.0.0 inside
telnet timeout 5
ssh 172.20.0.0 255.255.0.0 inside
ssh timeout 20
console timeout 0
threat-detection basic-threat
threat-detection statistics access-list
no threat-detection statistics tcp-intercept
webvpn
group-policy DefaultRAGroup internal
group-policy DefaultRAGroup attributes
dns-server value 172.20.2.4
vpn-tunnel-protocol l2tp-ipsec
default-domain value hq.vertique.com
username admin password <removed> privilege 15
tunnel-group DefaultRAGroup general-attributes
address-pool VPN-IP-Pool
authentication-server-group Radius
default-group-policy DefaultRAGroup
tunnel-group DefaultRAGroup ipsec-attributes
pre-shared-key *****
isakmp keepalive disable
tunnel-group DefaultRAGroup ppp-attributes
no authentication chap
authentication ms-chap-v2
class-map inspection_default
match default-inspection-traffic
policy-map type inspect dns preset_dns_map
parameters
  message-length maximum client auto
  message-length maximum 512
policy-map global_policy
class inspection_default
  inspect ftp
  inspect h323 h225
  inspect h323 ras
  inspect ip-options
  inspect netbios
  inspect rsh
  inspect rtsp
  inspect skinny
  inspect esmtp
  inspect sqlnet
  inspect sunrpc
  inspect tftp
  inspect sip
  inspect xdmcp
service-policy global_policy global
prompt hostname context
no call-home reporting anonymous
call-home
profile CiscoTAC-1
  no active
  destination address http https://tools.cisco.com/its/service/oddce/services/DDCEService
  destination address email callhome@cisco.com
  destination transport-method http
  subscribe-to-alert-group diagnostic
  subscribe-to-alert-group environment
  subscribe-to-alert-group inventory periodic monthly
  subscribe-to-alert-group configuration periodic monthly
  subscribe-to-alert-group telemetry periodic daily
Thanks in advance for any input!
2 Accepted Solutions
In that case, the default gateway of the server is pointing to the second gateway and the return traffic from the server doesn't pass through this particular ASA.
yup, you can't possibly have all the internet routes configured on the server, so yes, the server will definitely use default gateway to route back the traffic.
And no, it is not how the server would respond back to the same ASA where the traffic is coming from. Server will respond back by routing via its default gateway since the traffic is from the internet, it will use a default gateway coz you couldn't possibly configure static routes or have the whole internet in your server routing table.
As a test, just configure the server default gateway to point to this ASA, i am sure you will be able to access it from the internet with no issue.
16 Replies 16
jayturish
Community Member
Your first rules look funky. Are you doing one to one NAT or one to many NAT?
If you are just using your outside IP as your public and port forwarding to one or more internal hosts, your lines should look like this:
object-group service DM_INLINE_TCP_1 tcp
port-object eq 15961
port-object eq 88
port-object eq 9000
access-list outside_access_in extended permit icmp any any
access-list outside_access_in extended permit tcp any any object-group DM_INLINE_TCP_1
static (inside,outside) udp interface 15961 172.16.0.3 15961 netmask 255.255.255.255
static (inside,outside) tcp interface 15961 172.16.0.3 15961 netmask 255.255.255.255
static (inside,outside) tcp interface 88 172.16.0.3 88 netmask 255.255.255.255
static (inside,outside) tcp interface 67 172.16.0.3 67 netmask 255.255.255.255
static (inside,outside) tcp interface 68 172.16.0.3 68 netmask 255.255.255.255
static (inside,outside) tcp interface 9000 172.16.0.3 9000 netmask 255.255.255.255
and your inside NAT statement also is wierd
here is mine
global (inside) 1 interface
nat (inside) 1 0.0.0.0 0.0.0.0
Jennifer Halim
Your static PAT configuration and access-list looks correct to me.
Are you getting any hitcount on the access-list?
Are you able to telnet on those ports from the internet?
If you try to change it to the following (ie: using the interface keyword instead of the actual IP):
access-list outside_access_in extended permit tcp any interface outside eq 2332
access-list outside_access_in extended permit tcp any interface outside eq 5901
access-list outside_access_in extended permit tcp any interface outside eq 5500
access-list outside_access_in extended permit tcp any interface outside eq 5705
access-list outside_access_in extended permit tcp any interface outside eq 81
does it work?
The traffic does hit the firewall rule and still does not work with the change mentioned with the desired service or ssh over these ports. This is a many to one NAT with the single public IP.
I am using the ASA version 8.2(5) and the ASDM version 6.4(5) with this config.
If the traffic does hit the firewall rule, can you pls share the output of :
show conn | i
Is there any firewall or access rules on the server itself that prevents inbound/incoming connection from the internet?
The output of the show conn | i is blank ...
When I do a packet trace I get the following
VTQFW# packet-tracer input outside tcp 2332 172.20.2.7 2332 detailed
Phase: 1
Type: ACCESS-LIST
Subtype:
Result: ALLOW
Config:
Implicit Rule
Additional Information:
Forward Flow based lookup yields rule:
in  id=0xc97cbed8, priority=1, domain=permit, deny=false
        hits=60899, user_data=0x0, cs_id=0x0, l3_type=0x8
        src mac=0000.0000.0000, mask=0000.0000.0000
        dst mac=0000.0000.0000, mask=0100.0000.0000
Phase: 2
Type: ROUTE-LOOKUP
Subtype: input
Result: ALLOW
Config:
in   172.20.0.0      255.255.0.0     inside
Phase: 3
Type: ACCESS-LIST
Subtype:
Result: DROP
Config:
Implicit Rule
in  id=0xc97d2af0, priority=500, domain=permit, deny=true
        hits=0, user_data=0x6, cs_id=0x0, reverse, flags=0x0, protocol=0
        src ip=, mask=255.255.255.255, port=0
        dst ip=0.0.0.0, mask=0.0.0.0, port=0, dscp=0x0
Result:
input-interface: outside
input-status: up
input-line-status: up
output-interface: inside
output-status: up
output-line-status: up
Action: drop
Drop-reason: (acl-drop) Flow is denied by configured rule
When you use the packet-tracer, the destination ip address should be the ASA outside interface IP, not the private IP/real IP of the server, because when you actually connect from the internet/outside, you would be connecting to the public IP/NATed IP, not the private IP.
Here is how you should run the packet tracer:
packet-tracer input outside tcp 2332 2332 detailed
After using the correct syntax with the trace the traffic is allowed through the firewall ...
Result:
input-status: up
output-status: up
Action: allow
Excellent, good to hear it's working correctly now.
Pls kindly mark the post answered so others can learn from it. Thank you.
The issue is still there. The traffic has always traversed the firewall, i was just using packet tracer incorrectly in troubleshooting. It almost has to be some thing in the NATing at this point doesn't it?
If the issue is still there, i can assure you that it is not the ASA at this point.
If you use packet tracer and it allows the traffic through, then the ASA configuration is OK.
I would be looking into the server itself to see if there is any firewall on the server itself that might be preventing inbound connection from the internet.
I can ssh into the server from the internet using a second gateway we currently have (and phasing out once this is resolved) so it is not the server as far as I can see it. Now you understand why I am so perplexed!
Shouldn't the server respond back to the ASA since it initiated the request? I don't have the server set to send all traffic through the other gateway ...
A default gateway is the node on the computer network that the network software uses when an IP address does not match any other routes in the routing table.
