Port Forwarding Outside Interface
chevymannie
Level 4
Level 4
Wanted to make sure I had my syntax right for this.  I'm trying to forward a port say 8030 from my outside interface to a host on the inside on 3389.
Here's what I have so far
object network 1.1.1.1
 host 1.1.1.1
 nat (inside,outside) static interface service tcp 3389 8030
access-list outside_in extended permit tcp any host 1.1.1.1 eq 8030
Trying to get this to work and I'm not seeing any hits on my outside ACL.
  • 1.1.1.1 is your internal IP in this scenario?
  • In the ACL you have to use the real port, same as you use the real IP (1.1.1.1):
access-list outside_in extended permit tcp any host 1.1.1.1 eq 3389
If you found this post helpful, please give it Kudos. If my answer solves your problem, please click Accept as Solution so others can benefit from it.
Worked like a charm once I put the real port in the outside ACL.  Thanks Karsten.
Rahul Govindan
NAT Syntax looks ok to me, just need to check the ACL port to . You can use this guide as reference:
https://supportforums.cisco.com/document/132066/asa-nat-83-nat-operation-and-configuration-format-cli#NETWORK-OBJECT-NAT
Can you run a packet-tracer from outside to inside to see what happens to the packet?
packet-tracer input outside tcp 4.2.2.2 12345 <public interface ip> 8030 detailed
