Problem Agent SourceFire
crusier2015
Level 3
Level 3
i'm trying to configure AD agent, but always return the following error appears:
I checked LOGs of agent, the follow message appears:
"26/09/2015 20:48:23","debug","[0001] - Error connecting to 192.168.0.15: System.Management.ManagementException: User credentials cannot be used for local connections
   at System.Management.ThreadDispatch.Start()
   at System.Management.ManagementScope.Initialize()
   at SFCo ..."
I followed the tutorial bellow:
http://www.cisco.com/c/en/us/support/docs/security/firesight-management-center/118637-configure-firesight-00.html
Marvin Rhoads
You need to install the User Agent on a computer other than the AD server that you are pointing it to. This is a limitation of WMI as it cannot use domain credentials when running WMI scripts on the locahost.
7 Replies 7
Marvin Rhoads
You are correct, when i installed the agent on another server, worked!
Tks
Binyam Demissie
Just to add to the suggested solution:
+ Installing the user Agent on a remote computer for remote access is NOT required. Its an option, but not required. You have two options:
Option #1
Install locally and add the AD server as below for the user agent to be able to report user activities in *real-time*. Real time events are not available when installed on another computer and then remotely accessed.
Server Name/IP Address : localhost
Domain: [ Blank ]
Authorized User: [ Blank ]
Password: [ Blank ]
Local Login IP Address: [ select the IP address]
Option #2 -
Install on another computer and add the up to 5 AD DC to the user agent.
- here you will need to user Server IP, domain, username, password for this to work.
- Additionally you will need the following configuration on the AD DCs to allow the user to read Security Logs *REMOTELY*.  This is NOT required for local install on the AD DC itself.
~ Binyam (TAC)
Good info Binyam - thanks.
I'd suggest updating the Technote on SFUA to reflect this valuable addition.
I went with Binyam Demissie Option #1 and no issues.
Thx Binyam!
Thank you so much for solving the problem that I did not solve in 30 minutes
a ali
Frequent Visitor
Frequent Visitor
i have the same issue , as we added two active directory on agent one of them working fine and another one status is not available and after check agent log see this error ,
[0002] - Error connecting to 172.16.1.57: System.UnauthorizedAccessException: Access is denied. (Exception from HRESULT: 0x80070005 (E_ACCESSDENIED))
at System.Management.ManagementScope.Initialize( ...
