Problem bouncing throw a PIX
madskirke
Community Member
Problem bouncing throw a PIX.
In my company we have a Hosted Rack white a PIX firewall. The firewall is mange by the Hosting Company.
There say the following about my problem, white bouncing from the inside of the firewall:
Firewall setup doesn't allow machines
inside the firewall to use externally visible IP's to
access other machines inside the firewall. For example,
Server-x cannot use the externally visible IP 213.173.22.22
to talk to "xxx.xxx.com" which is a machine on the
same level as the Server-x system within the firewall.
Server-x is forced to use it's internal address 10.30.10.10.
Is this right? cant you bounche trow a fw?
Sorry about my crappy English.
/Mads
owillins
Level 11
Level 11
If your DNS resides outside the PIX (or across one of its DMZs) you may use the alias command on the Cisco Secure PIX Firewall to fix the DNS packet.
http://www.cisco.com/warp/public/110/pixfaq.shtml
