Problem establishing tunnel PIX -> VPNC
sbrozius
I'm trying to establish a tunnel from a PIX to a VPN Concentrator, but the tunnel does not come up. The PIX tries to establish, but somehow, it can't.
On the VPN Concentrator, I have the attached notifications in the event log.
Could you provide me with a possible solution or action to take?
Thanx!
jackko
Level 7
Level 7
it's a bit hard to troubleshoot without reading the config.
below is the sample codes for pix lan-lan vpn:
access-list 101 permit ip 192.168.2.0 255.255.255.0 192.168.1.0 255.255.255.0
access-list 121 permit ip 192.168.2.0 255.255.255.0 192.168.1.0 255.255.255.0
ip address outside 1.1.1.2 255.255.255.0
ip address inside 192.168.2.1 255.255.255.0
global (outside) 1 interface
nat (inside) 0 access-list 101
nat (inside) 1 0.0.0.0 0.0.0.0 0 0
sysopt connection permit-ipsec
crypto ipsec transform-set myset esp-3des esp-md5-hmac
crypto map myvpn 10 ipsec-isakmp
crypto map myvpn 10 match address 121
crypto map myvpn 10 set peer 1.1.1.1
crypto map myvpn 10 set transform-set myset
crypto map myvpn interface outside
isakmp enable outside
isakmp key cisco123 address 1.1.1.1 netmask 255.255.255.255 no-xauth no-config-mode
isakmp identity address
isakmp nat-traversal 20
isakmp policy 10 authentication pre-share
isakmp policy 10 encryption 3des
isakmp policy 10 hash md5
isakmp policy 10 group 2
isakmp policy 10 lifetime 86400
for the concentrator, go administration > file management, click "view" on the file "config", save a copy and post it. one point needs to be noticed is that public ips needs to be masked.
Thanks for the reply...
I forgot to update this Q last friday after I've got it up and running. Problem was that our VPNC is in a DMZ. The firewall had a route in place which screwed up the return-route from the VPNC to the PIX; no traffic ever returned to the initiating PIX.
After removing that faulty route in the firewall, everything worked like a charm.
Strange thing was that we have more of such VPN-tunnels in place, but only this one gave problems.
Thanks again, and a good new year to you!
it's good to learn that your issue has been resolved.
happy new year!
