Problem In Policy
shivlu jain
Level 9
Level 9
Dear All
I am binding the policy in ASA 5500, everthing works fine except we are not able to download the mail attachment from MSN.
The ASA OS Version is 8.2(1).
regex domainlist2 ".*sandai.*"
regex domainlist4 ".*megaupload.*"
regex domainlist5 ".*sendspace.*"
regex domainlist6 ".*rapidshare.*"
access-list inside_mpc extended permit tcp any any eq www
access-list inside_mpc extended permit tcp any any eq 8080
class-map type regex match-any DomainBlockList
match regex domainlist2
match regex domainlist4
match regex domainlist5
match regex domainlist6
class-map type inspect http match-all BlockDomainsClass
match request header host regex class DomainBlockList
class-map httptraffic
match access-list inside_mpc
policy-map type inspect http http_inspection_policy
parameters
protocol-violation action drop-connection
match request method connect
drop-connection log
class BlockDomainsClass
reset log
policy-map inside-policy
class httptraffic
service-policy inside-policy interface Internal
regards
shivlu jain
Farrukh Haroon
Try removing the non-standard HTTP check and see how it goes:
no protocol-violation action drop-connection
Or change the action from drop to logging only
Farrukh
