Problem on acl filter trafic
Didier DRIEUX
Frequent Visitor
Frequent Visitor
I have a problem with rule of FWSM.
Message log :
Aug  3 16:38:57 PIX-Part Aug 03 2010 16:38:57: %FWSM-3-106010: Deny
> inbound tcp src filiales:10.113.248.17/4144 dst
> dmzpub-part:146.249.250.133/21
> Aug  3 16:39:00 PIX-Part Aug 03 2010 16:39:00: %FWSM-3-106010: Deny
> Aug  3 16:39:06 PIX-Part Aug 03 2010 16:39:06: %FWSM-3-106010: Deny
The rule is :
access-list filiales_access_in extended permit tcp 10.113.248.16
> 255.255.255.240 host 146.249.250.133 object-group S_FTP
Yet the access-list capture match well the traffic:
fw-tiers# sh access-list cap_MDA
> access-list cap_MDA; 2 elements
> access-list cap_MDA line 1 extended permit ip 10.113.248.16
> 255.255.255.240 host 146.249.250.133 (hitcnt=12) 0x2fe4c3b1
> access-list cap_MDA line 2 extended permit ip host 146.249.250.133
> 10.113.248.16 255.255.255.240 (hitcnt=0) 0x67ee5327
But not those that used to filter the traffic :
sh access-list filiales_access_in | inc 10.113.248.16 access-list
> filiales_access_in line 2 extended permit tcp
> 10.113.248.16 255.255.255.240 host 146.249.250.133 object-group S_FTP
> 0x7188a1ec access-list filiales_access_in line 2 extended permit tcp
> 10.113.248.16 255.255.255.240 host 146.249.250.133 eq ftp (hitcnt=0)
> 0xdc2693b4
> 10.113.248.16 255.255.255.240 host 146.249.250.133 eq ftp-data
> (hitcnt=0) 0x33118715
We have tried to disable FTP inspection without succès.
The version of FWSM is
FWSM Firewall Version 4.0(5)
Device Manager Version 6.1(3)F
Thanks for your help
6 Replies 6
mirober2
Can you check the output of 'show run access-group' to ensure that the ACL is applied to the correct interface?
-Mike
Hello Mike,
See on attachement the result of the command.
Hello Mike,
The problem has been resolved. It' was a NAT Configuration problem.
Didier
Andrew Ossipov
Hello Didier,
This looks like a NAT issue rather than an ACL deny. Please ensure that the NAT configuration is properly mapping 146.249.250.133 from'dmzpub-part' to 'filiales' and/or NAT Control is turned off.
Andrew
Hi Andrew,
The "nat-control" command is not present on the configuration. It has been disabled a few weeks ago to allow traffic to pass without NAT.
Is it necessary to recreate a rule of NAT ?
Hello Didier,
It appears that some existing NAT configuration is preventing the xlate from being created (likely by a NAT reverse path check). You should go through the NAT configuration ('show run nat', 'show run global', and 'show run static') between the interfaces in question to make sure bi-directional connectivity is allowed. I would also suggest checking the relative security levels with 'show nameif' command.
Andrew
