Showing results forĀ
Search instead forĀ
Did you mean:Ā
Problem on port forwarding on ASA 5512x?
rechard_hk
Dear All,
I would like to ask you that currently i have two public ip add
and i would like to use port forwoarding. as below i use one public ip add
and other one i don't know how to configure.
Public ip add 203.10.1.1
access-list outside_acl_in extended permit tcp any host 192.168.1.2 eq www
object network www-10
nat (inside,outside) static interface service tcp www www
so i would like to add other public 203.10.1.2 to 192.168.1.3 port www
Best Regards,
rechard
Julio Carvajal
Hello Rechard,
Same thing, just use the IP address instead of the "interface" keyword.
static (inside,outside) tcp 203.10.1.2 80 192.168.1.3 80
access-list outside_acl permit tcp any host 203.10.1.2 eq 80
Check my blog at http:laguiadelnetworking.com for further information.
Cheers,
Julio Carvajal Segura
Julio Carvajal
Senior Network Security and Core Specialist
CCIE #42930, 2xCCNP, JNCIP-SEC
Dear Juilo,
Is it working on ASA 5512 V.9.1.1?
Currently i'm using
host 192.168.1.2
Best Regards,
Rechard
Hey Rechard
Do this
host 192.168.1.3
nat (inside,outside) static 203.10.1.2 service tcp www www
Vishaw
You showed  us the configuration on version 8.2 or lower but wanted on 8.3 or higher... lol.
OK, that being said
object network Inside_Server_2
host 192.168.1.3
Object network Outside_Server_2
host 203.10.1.2
nat (inside,outside) 1 source static Inside_Server_2 Outside_Server_2
access-list outside_acl_in permit tcp any host 192.168.1.3 eq 80
Remember to rate all of the answers
Check my blog at http:laguiadelnetworking.com  and subscribe so you can get daily information about networking.
Cheers,
Julio Carvajal
