Problem to save changes
MarcoPoffal
Community Member
We have a big trouble, becase when we try to "save changes" in a Firewall ASA-5520 this show an error FAILED, and because of this we have lost parts of the configuration. Did you know any solution?
sputnik# wr mem
Building configuration...
No memory available
Error executing command
[FAILED]
sputnik# sh mem
Free memory:        88792120 bytes (17%)
Used memory:       448078792 bytes (83%)
Total memory:      536870912 bytes (100%)
sputnik# sh cpu
CPU utilization for 5 seconds = 1%; 1 minute: 3%; 5 minutes: 4%
sputnik# dir
Directory of disk0:/
214    -rwx  14635008    21:14:46 May 05 2009  asa803-k8.bin
215    -rwx  6851212     21:16:08 May 05 2009  asdm-603.bin
216    drwx  4096        15:11:12 Nov 14 2011  log
217    drwx  4096        19:46:18 Aug 18 2007  crypto_archive
218    -rwx  16275456    09:21:52 Sep 11 2009  asa821-k8.bin
220    -rwx  11348300    09:23:28 Sep 11 2009  asdm-621.bin
202    drwx  4096        17:05:50 Sep 14 2009  coredumpinfo
62881792 bytes total (13209600 bytes free)
sputnik# wr mem
No memory available
[FAILED]
Thanks!
Marvin Rhoads
You may have a bad Compact Flash (CF) card. startup-config (where the config is stored when you do wr mem) is on a hidden directory of disk0: (the CF).
sh mem is showing you the DRAM, separate from the flash memory.
Do you have an HA pair? If so you could failover to the standby, break the HA pair and then see if the standby unit allows you to store the running-config to startup.
Hope this helps.
Julio Carvajal
Hello Marco,
Adding to what Marvin said, I worked on one case like the one you are having this week.
Can you do a fsck flash:
This will run a scan on the flash to detect if there are some corrupted files.
Here is one link where you get some information from this memory issues.
http://www.cisco.com/en/US/products/ps6120/products_tech_note09186a0080b95d3d.shtml
Can you provide the show version of your ASA and also show blocks
Julio
Julio Carvajal
Senior Network Security and Core Specialist
CCIE #42930, 2xCCNP, JNCIP-SEC
Hi Julio:
I do a fsck flash and the results are the next:
sputnik# fsck flash:
fsck of flash: complete
When we try to save the changes appears this error:
sputnik# wr mem
No memory available
[FAILED]
I can not reboot the firewall, because we are apply a lot of changes, and with the restart all those changes will be lost.
Do you know something else?
Thanks!
Gonzalo,
You can always backup the running configuration locally (to your workstation). Under ASDM, "Tools, Backup Configuration". After a reboot, you can restore that backup.
