Problem with a Cisco ASA 5510
frbachel05
I post this message because I encounter a problem with my Cisco ASA
Quick Schema:
Plan:
The network 10.0.2.0 must have access to:
- Internet via the interface 10.0.1.1
- Client network 10.0.3.0 via a Citrix connection
Internet access:
- NAT rule:
global (outside) 1 interface
nat (inside) 1 10.0.2.0 255.255.255.0
- Default route:
Outside route 0.0.0.0 0.0.0.0 10.0.1 1 1
Network Access Client:
- Added the way to the client network that has no IP interface on the FW:
route inside 10.0.3.0 255.255.255.0 10.0.2.1 1
- Order same-security-traffic permit intra-interface to enter and exit from the same interface.
- Adding a NAT Exempt to join the client:
Access-list extended permit ip 10.0.2.0 IN_NAT_0 10.0.3.0 255.255.255.0 255.255.255.0
I'm not sure that this rule is necessary ...
Result:
From the LAN 10.0.2.0, I go on internet with NAT rule but i can't connect to the network client 10.0.3.0.
For info:
- NAT for the client network is managed by the client router.
- When I add the route10.0.3.0 255.255.255.0 10.0.2.1 directly on client PC, il doesn't pass through the firewall and it works.
So, there is a problem with my FW config.
Logs:
Errors: portmap translation creation failed for udp src inside: 10.0.2.10 / X dst inside: 10.0.3.X / X
I don't understand the link with my problem...
Config ASA:
I reset the config
and i have not others config on the FW
Questions?
Should I add specific commands to access a network that is not directly connected to the FW from a network who is?
Normally, with  the command same-security-traffic permit intra-interface, you can enter  and exit through the same interface...
Thank you in advance for your help and sorry for my poor english!
15 Replies 15
Hey glad to know that. Please mark this as answered if all is done.
Cheers,
Prapanch
