Showing results forĀ
Search instead forĀ
Did you mean:Ā
Problem with CSM Performance Monitor
Luis Carranza
Hi guys
I've a problem trying to add a device into the Perfomance Monitor because when I'm trying to importing the ASA i got a error message:
The Device x.x.x.x could not be imported because the object identifier is not  supported: 1.3.6.1.4.1.9.1.773.
1 device failed to be imported. To monitor  this device, you must import it again.
Performance Monitor Version: 3.3
I was checking the device against another one and it have the same configuration so If anyone have any comment to solve this problem I really appreciate it.
Regards.
Nicolas Fournier
Hi Luis,
Would be any chance the ASA you are trying to import be a 5510 running in multi-context mode?
If so, there is a bug which is unfortunately internal for now which describes the situation you are facing.
This bug is fixed in Perfmon 4.0 so if you can go for an upgrade, the import should be successful afterwards.
HTH,
Nicolas
