Problem with failover on PIX and ASA with OS 7.2.1
lukasmecir
Hello all,
I have this problem: I have two PIXs connected each other for LAN and stateful failover. They are connected by UTP cable through interfaces Ethernet0, where are two sub-interfaces are made (1 for LAN FO, 1 for stateful failover). With OS 7.1.(2) everything is OK, FO is fully functional. But after upgrade to OS 7.2.(1) I get this message on standby unit after standby unit is power on:
Detected an Active mate
Beginning configuration replication from mate.
ERROR: Interface is in use by failover. You must disable failover first to execute this command
End configuration replication from mate.
And these command are eliminated from configuration on primary unit:
failover link state Ethernet0/0.25
failover interface ip state 192.168.253.1 255.255.255.0 standby 192.168.253.2
I tried the same on 2 ASAs 5510 with the same result.
Does anyone know any solution for this? Is this bug in OS 7.2.(1) (but in Cisco Bug Tool I find anything about this)? Thanks in advance for any info. Config of primary unit is here:
interface Ethernet0
interface Ethernet0.24
description LAN Failover Interface
vlan 24
interface Ethernet0.25
description STATE Failover Interface
vlan 25
interface Ethernet1
nameif inside
security-level 100
ip address 192.168.1.1 255.255.255.0 standby 192.168.1.3
interface Ethernet2
shutdown
no nameif
no security-level
no ip address
interface Ethernet3
nameif outside
security-level 0
ip address xxx.xxx.xxx.xxx 255.255.255.240 standby xxx.xxx.xxx.xxx
interface Ethernet4
shutdown
no nameif
no security-level
no ip address
interface Ethernet5
shutdown
no nameif
no security-level
no ip address
passwd xxx
ftp mode passive
pager lines 24
mtu inside 1500
mtu outside 1500
failover
failover lan unit primary
failover lan interface failover Ethernet0.24
failover lan enable
failover link state Ethernet0.25
failover interface ip failover 192.168.254.1 255.255.255.0 standby 192.168.254.2
Lukas Mecir, Albit Technologies
a.kiprawih
Level 7
Level 7
When you configure primary unit, enter the "failover" command only after you finished keying-in all the other failover commands. This will prevent the failover process to run immediately without all required parameters. Make sure all interfaces assigned with IPs.
http://www.cisco.com/en/US/products/ps6120/products_configuration_guide_chapter09186a008063b31a.html#wp1124508
Rgds,
AK
