Bookmark
Subscribe
1494
Problem with traffic between 2 interfaces, Still no solution...
gasparmenendez
Level 3
Level 3
Hi folks,
I'm having trouble with traffic between different subnets connected to different interfaces. In interface CARRIERS is connected a server with ip address 10.227.224.11 and in interface INSIDE_Prueba I have connected my PC with ip address 192.168.199.30. I can't ping from my PC to the server, it doesn't answer. However, I can see in my ASA's ASDM (5580 8.4(5) and Device Manager Version 7.1(1)52) the Hit counter increasing when I send ping. Here's what I configured:
access-list INSIDE_Prueba_access_out extended permit ip 10.227.224.0 255.255.252.0 any (here's where the counter increases)
and
access-list CARRIERS_access_out extended permit ip 192.168.199.0 255.255.255.0 10.227.224.0 255.255.252.0
Can anybody help me please??
Thanks in advance.
23 Replies 23
here's capture in the other way:
gaspar@gaspar-Lenovo-ideapad-310-15ISK ~ $ sudo tcpdump -i enp1s0 | grep 10.227.224.8
tcpdump: verbose output suppressed, use -v or -vv for full protocol decode
listening on enp1s0, link-type EN10MB (Ethernet), capture size 262144 bytes
13:49:56.454958 IP 10.227.224.8 > 192.168.199.30: ICMP echo request, id 1, seq 1239, length 40
13:49:56.454976 IP 192.168.199.30 > 10.227.224.8: ICMP echo reply, id 1, seq 1239, length 40
13:49:57.487287 IP 10.227.224.8 > 192.168.199.30: ICMP echo request, id 1, seq 1240, length 40
13:49:57.487306 IP 192.168.199.30 > 10.227.224.8: ICMP echo reply, id 1, seq 1240, length 40
13:49:58.519610 IP 10.227.224.8 > 192.168.199.30: ICMP echo request, id 1, seq 1241, length 40
13:49:58.519624 IP 192.168.199.30 > 10.227.224.8: ICMP echo reply, id 1, seq 1241, length 40
13:49:59.566572 IP 10.227.224.8 > 192.168.199.30: ICMP echo request, id 1, seq 1242, length 40
13:49:59.566596 IP 192.168.199.30 > 10.227.224.8: ICMP echo reply, id 1, seq 1242, length 40
13:50:00.598874 IP 10.227.224.8 > 192.168.199.30: ICMP echo request, id 1, seq 1243, length 40
13:50:00.598911 IP 192.168.199.30 > 10.227.224.8: ICMP echo reply, id 1, seq 1243, length 40
13:50:01.632839 IP 10.227.224.8 > 192.168.199.30: ICMP echo request, id 1, seq 1244, length 40
13:50:01.632855 IP 192.168.199.30 > 10.227.224.8: ICMP echo reply, id 1, seq 1244, length 40
13:50:02.667957 IP 10.227.224.8 > 192.168.199.30: ICMP echo request, id 1, seq 1245, length 40
13:50:02.667987 IP 192.168.199.30 > 10.227.224.8: ICMP echo reply, id 1, seq 1245, length 40
13:50:03.701705 IP 10.227.224.8 > 192.168.199.30: ICMP echo request, id 1, seq 1246, length 40
13:50:03.701734 IP 192.168.199.30 > 10.227.224.8: ICMP echo reply, id 1, seq 1246, length 40
13:50:04.738270 IP 10.227.224.8 > 192.168.199.30: ICMP echo request, id 1, seq 1247, length 40
13:50:04.738287 IP 192.168.199.30 > 10.227.224.8: ICMP echo reply, id 1, seq 1247, length 40
13:50:05.770705 IP 10.227.224.8 > 192.168.199.30: ICMP echo request, id 1, seq 1248, length 40
13:50:05.770744 IP 192.168.199.30 > 10.227.224.8: ICMP echo reply, id 1, seq 1248, length 40
13:50:06.803582 IP 10.227.224.8 > 192.168.199.30: ICMP echo request, id 1, seq 1249, length 40
13:50:06.803597 IP 192.168.199.30 > 10.227.224.8: ICMP echo reply, id 1, seq 1249, length 40
13:50:07.835389 IP 10.227.224.8 > 192.168.199.30: ICMP echo request, id 1, seq 1250, length 40
13:50:07.835402 IP 192.168.199.30 > 10.227.224.8: ICMP echo reply, id 1, seq 1250, length 40
13:50:08.869768 IP 10.227.224.8 > 192.168.199.30: ICMP echo request, id 1, seq 1251, length 40
13:50:08.869800 IP 192.168.199.30 > 10.227.224.8: ICMP echo reply, id 1, seq 1251, length 40
13:50:09.904622 IP 10.227.224.8 > 192.168.199.30: ICMP echo request, id 1, seq 1252, length 40
13:50:09.904647 IP 192.168.199.30 > 10.227.224.8: ICMP echo reply, id 1, seq 1252, length 40
^C139 packets captured
160 packets received by filter
0 packets dropped by kernel
9 packets dropped by interface
Thanks.
My las shot man.
 Apply this:
same-security-traffic permit inter-interface
Hi friend,
here's ping from 10.227.224.8 to 192.168.199.30 (ASA's ASDM):
6|Sep 04 2017|10:24:34|302015|192.168.199.30|50633|216.58.219.35|443|Built outbound UDP connection 1061824194 for OUTSIDE:216.58.219.35/443 (216.58.219.35/443) to INSIDE_Prueba:192.168.199.30/50633 (170.X.X.2/50633)
6|Sep 04 2017|10:24:34|305011|192.168.199.30|50633|170.X.X.2|50633|Built dynamic UDP translation from INSIDE_Prueba:192.168.199.30/50633 to OUTSIDE:170.X.X.2/50633
6|Sep 04 2017|10:24:34|302013|192.168.199.30|44288|216.58.219.35|443|Built outbound TCP connection 1061824192 for OUTSIDE:216.58.219.35/443 (216.58.219.35/443) to INSIDE_Prueba:192.168.199.30/44288 (170.X.X.2/44288)
6|Sep 04 2017|10:24:34|305011|192.168.199.30|44288|170.X.X.2|44288|Built dynamic TCP translation from INSIDE_Prueba:192.168.199.30/44288 to OUTSIDE:170.X.X.2/44288
6|Sep 04 2017|10:24:34|302016|209.244.0.3|53|192.168.199.30|54863|Teardown UDP connection 1061824150 for OUTSIDE:209.244.0.3/53 to INSIDE_Prueba:192.168.199.30/54863 duration 0:00:00 bytes 110
6|Sep 04 2017|10:24:34|302015|192.168.199.30|54863|209.244.0.3|53|Built outbound UDP connection 1061824150 for OUTSIDE:209.244.0.3/53 (209.244.0.3/53) to INSIDE_Prueba:192.168.199.30/54863 (170.X.X.2/54863)
6|Sep 04 2017|10:24:27|302013|192.168.199.30|54220|54.152.171.205|443|Built outbound TCP connection 1061818984 for OUTSIDE:54.152.171.205/443 (54.152.171.205/443) to INSIDE_Prueba:192.168.199.30/54220 (170.X.X.2/16236)
6|Sep 04 2017|10:24:27|305011|192.168.199.30|54220|170.X.X.2|16236|Built dynamic TCP translation from INSIDE_Prueba:192.168.199.30/54220 to OUTSIDE:170.X.X.2/16236
6|Sep 04 2017|10:24:27|302016|209.244.0.3|53|192.168.199.30|54863|Teardown UDP connection 1061818924 for OUTSIDE:209.244.0.3/53 to INSIDE_Prueba:192.168.199.30/54863 duration 0:00:00 bytes 376
6|Sep 04 2017|10:24:27|302015|192.168.199.30|54863|209.244.0.3|53|Built outbound UDP connection 1061818924 for OUTSIDE:209.244.0.3/53 (209.244.0.3/53) to INSIDE_Prueba:192.168.199.30/54863 (170.X.X.2/54863)
6|Sep 04 2017|10:24:27|302013|192.168.199.30|58414|35.201.97.85|443|Built outbound TCP connection 1061818687 for OUTSIDE:35.201.97.85/443 (35.201.97.85/443) to INSIDE_Prueba:192.168.199.30/58414 (170.X.X.2/58414)
6|Sep 04 2017|10:24:27|305011|192.168.199.30|58414|170.X.X.2|58414|Built dynamic TCP translation from INSIDE_Prueba:192.168.199.30/58414 to OUTSIDE:170.X.X.2/58414
6|Sep 04 2017|10:24:27|302016|209.244.0.3|53|192.168.199.30|54863|Teardown UDP connection 1061818651 for OUTSIDE:209.244.0.3/53 to INSIDE_Prueba:192.168.199.30/54863 duration 0:00:00 bytes 236
this ping is working fine.
Now the ping from 192.168.199.30 to 10.227.224.8 (ASA's ASDM):
4|Sep 04 2017|10:31:46|313004|||||Denied ICMP type=0, from laddr 10.227.224.8 on interface CARRIERS to 192.168.199.30: no matching session
6|Sep 04 2017|10:31:46|302020|10.227.224.8|0|192.168.199.30|4929|Built inbound ICMP connection for faddr 10.227.224.8/0 gaddr 192.168.199.30/4929 laddr 192.168.199.30/4929
6|Sep 04 2017|10:31:46|302021|10.227.224.8|0|192.168.199.30|4929|Teardown ICMP connection for faddr 10.227.224.8/0 gaddr 192.168.199.30/4929 laddr 192.168.199.30/4929
4|Sep 04 2017|10:31:45|313004|||||Denied ICMP type=0, from laddr 10.227.224.8 on interface CARRIERS to 192.168.199.30: no matching session
6|Sep 04 2017|10:31:45|302020|10.227.224.8|0|192.168.199.30|4929|Built inbound ICMP connection for faddr 10.227.224.8/0 gaddr 192.168.199.30/4929 laddr 192.168.199.30/4929
6|Sep 04 2017|10:31:45|302021|10.227.224.8|0|192.168.199.30|4929|Teardown ICMP connection for faddr 10.227.224.8/0 gaddr 192.168.199.30/4929 laddr 192.168.199.30/4929
4|Sep 04 2017|10:31:44|313004|||||Denied ICMP type=0, from laddr 10.227.224.8 on interface CARRIERS to 192.168.199.30: no matching session
6|Sep 04 2017|10:31:44|302020|10.227.224.8|0|192.168.199.30|4929|Built inbound ICMP connection for faddr 10.227.224.8/0 gaddr 192.168.199.30/4929 laddr 192.168.199.30/4929
6|Sep 04 2017|10:31:44|302021|10.227.224.8|0|192.168.199.30|4929|Teardown ICMP connection for faddr 10.227.224.8/0 gaddr 192.168.199.30/4929 laddr 192.168.199.30/4929
4|Sep 04 2017|10:31:43|313004|||||Denied ICMP type=0, from laddr 10.227.224.8 on interface CARRIERS to 192.168.199.30: no matching session
6|Sep 04 2017|10:31:43|302020|10.227.224.8|0|192.168.199.30|4929|Built inbound ICMP connection for faddr 10.227.224.8/0 gaddr 192.168.199.30/4929 laddr 192.168.199.30/4929
6|Sep 04 2017|10:31:43|302021|10.227.224.8|0|192.168.199.30|4929|Teardown ICMP connection for faddr 10.227.224.8/0 gaddr 192.168.199.30/4929 laddr 192.168.199.30/4929
4|Sep 04 2017|10:31:42|313004|||||Denied ICMP type=0, from laddr 10.227.224.8 on interface CARRIERS to 192.168.199.30: no matching session
6|Sep 04 2017|10:31:42|302020|10.227.224.8|0|192.168.199.30|4929|Built inbound ICMP connection for faddr 10.227.224.8/0 gaddr 192.168.199.30/4929 laddr 192.168.199.30/4929
6|Sep 04 2017|10:31:42|302021|10.227.224.8|0|192.168.199.30|4929|Teardown ICMP connection for faddr 10.227.224.8/0 gaddr 192.168.199.30/4929 laddr 192.168.199.30/4929
4|Sep 04 2017|10:31:41|313004|||||Denied ICMP type=0, from laddr 10.227.224.8 on interface CARRIERS to 192.168.199.30: no matching session
6|Sep 04 2017|10:31:41|302020|10.227.224.8|0|192.168.199.30|4929|Built inbound ICMP connection for faddr 10.227.224.8/0 gaddr 192.168.199.30/4929 laddr 192.168.199.30/4929
6|Sep 04 2017|10:31:41|302021|10.227.224.8|0|192.168.199.30|4929|Teardown ICMP connection for faddr 10.227.224.8/0 gaddr 192.168.199.30/4929 laddr 192.168.199.30/4929
4|Sep 04 2017|10:31:40|313004|||||Denied ICMP type=0, from laddr 10.227.224.8 on interface CARRIERS to 192.168.199.30: no matching session
6|Sep 04 2017|10:31:40|302020|10.227.224.8|0|192.168.199.30|4929|Built inbound ICMP connection for faddr 10.227.224.8/0 gaddr 192.168.199.30/4929 laddr 192.168.199.30/4929
maybe that helps...???
anyway regarding what you suggest about same-security-traffic I don't see the point since all my interfaces have different security levels, but I try it anyway.
Thanks.
 Try to allow ICMP on the rules.
Which kind of access do you intend to perform?  For TCP/UDP must be working...
not working....I'll continue looking for help
Thanks.
I think I know what´s wrong. You may have not inspection enable.
Take a look with the command :
show run policy-map
If you dont have inspect icmp, then, run this:
policy-map global_policy
class inspection_default
inspect icmp
I think I have:
ASA5580# show run policy-map
policy-map type inspect dns preset_dns_map
 parameters
  message-length maximum client auto
  message-length maximum 512
  inspect ftp
  inspect h323 h225
  inspect h323 ras
  inspect ip-options
  inspect netbios
  inspect rsh
  inspect rtsp
  inspect skinny
  inspect esmtp
  inspect sqlnet
  inspect sunrpc
  inspect tftp
  inspect sip
  inspect xdmcp
  inspect icmp
  inspect icmp error
any more ideas???
thanks.
according to packet-trace everything is ok:
ASA5580# Packet-tracer input inside_prueba icmp 192.168.199.30 8 0 10.227.224.8
Phase: 1
Type: CAPTURE
Subtype:
Result: ALLOW
Config:
Additional Information:
MAC Access list
Phase: 2
Type: ACCESS-LIST
Subtype:
Result: ALLOW
Config:
Implicit Rule
MAC Access list
Phase: 3
Type: ROUTE-LOOKUP
Subtype: input
Result: ALLOW
Config:
in   10.227.224.0    255.255.252.0   CARRIERS
Phase: 4
Type: ACCESS-LIST
Subtype: log
Result: ALLOW
Config:
access-group INSIDE_Prueba_access_in in interface INSIDE_Prueba
access-list INSIDE_Prueba_access_in extended permit ip object 192.168.199.0 any
Phase: 5
Type: IP-OPTIONS
Subtype:
Result: ALLOW
Config:
Phase: 6
Type: INSPECT
Subtype: np-inspect
Result: ALLOW
Config:
class-map inspection_default
 match default-inspection-traffic
  inspect icmp
service-policy global_policy global
Phase: 7
Type: INSPECT
Subtype: np-inspect
Result: ALLOW
Config:
Phase: 8
Type: VPN
Subtype: ipsec-tunnel-flow
Result: ALLOW
Config:
Phase: 9
Type: DEBUG-ICMP
Subtype:
Result: ALLOW
Config:
Phase: 10
Type: ACCESS-LIST
Subtype: log
Result: ALLOW
Config:
access-group CARRIERS_access_out out interface CARRIERS
access-list CARRIERS_access_out extended permit ip any 10.227.224.0 255.255.252.0
Phase: 11
Type: DEBUG-ICMP
Subtype:
Result: ALLOW
Config:
Phase: 12
Type: IP-OPTIONS
Subtype:
Result: ALLOW
Config:
Phase: 13
Type: FLOW-CREATION
Subtype:
Result: ALLOW
Config:
New flow created with id 1141115336, packet dispatched to next module
Result:
input-interface: INSIDE_Prueba
input-status: up
input-line-status: up
output-interface: CARRIERS
output-status: up
output-line-status: up
Action: allow
