Problems accessing ASP pages after PIX OS upgrade
baskervi
I recently upgraded a PIX from 6.3(3) to 6.3(5) for a client a couple of Fridays ago. Their network is flat, and consists of Win2K, WinXP, and MACs (running AppleTalk and IP). They have a single internal L2 3Com switch. The configuration is straightfoward - there are not LAN-to-LAN VPN tunnels, but there is configuration for the IPSec VPN client. The person managing the firewall before me had set the tunnel encryption to DES, so during the upgrade I increased the encryption level and added the following commands:
icmp permit any echo-reply outside
icmp permit any unreachable outside
icmp permit any time-exceeded outside
I can't imaging how these would have impacted anything.
After the upgrade, all workstations are having problems accessing ASP web pages. The ASP pages either don't load or are very slow. You can move the machine outside the firewall, and things work as expected. Given a flat L2 internal network or the PIX, I'd lean toward the PIX, but I'm at a loss.
Thank you.
I disabled fixup for http, but this didn't help.
smahbub
Level 6
Level 6
The issue may be due to activation key that you may not have upgraded.
There are a couple of reasons that you may need to upgrade the activation key on your PIX.
Your PIX does not currently have VPN-DES or VPN-3DES encryption enabled.
Note: VPN-DES encryption must be enabled for you to manage your PIX with the use of PDM. Registered users can obtain a free 56-bit VPN-DES activation key when they complete the PIX 56-bit License Upgrade Key form. VPN-3DES activation keys must be purchased through your local reseller or Cisco sales representative.
Your PIX currently does not have failover activated.
You upgrade from a connection-based license to a feature-based license
I just tracked the problem down a couple days ago and forgot about this post as no one had replied until yours. The problem was not necessarily with secure web pages - it happened on both secure and nonsecure pages. The problem was with switchport 1 of the PIX-501, which decided to flake out. I noticed that when I plugged in my laptop into another PIX switch port, I could access web pages that were not available for other users, i.e. links on msn.com. I ended up plugging the 48-port core switch into another PIX-501 switch port, and EVERYTHING now works. I have no idea what the problem is with the first switch port, and I have no idea why it decided to fail when it did. Given that the 4 port internal switch on the PIX is a L2 device and no errors were showing up on the interface counters, I didn't think of trying a different switchport at first.
hi
I am interested in knowing a bit more onto what could be the possible cause for the problem with port1 which basically blocked the access to secure/nonsecure pages,is it possible for you to post out the config of with public ip and the passwds masked so that it can be verified for any notable difference on the config part.
regds
I can only guess there is a hardware problem, as there aren't any switchport settings on the PIX-501. After I moved the corporate switch over to the new switch port, there have been some intermittent problems accessing web sites. These blips are temporary, but enough to call Cisco and get it replaced with smartnet. I had to remove a few lines from config because of too many characters...
PIX Version 6.3(3)
interface ethernet0 auto
interface ethernet1 100full
nameif ethernet0 outside security0
nameif ethernet1 inside security100
enable password password2
passwd password2
hostname PIX
domain-name domain.local
fixup protocol dns maximum-length 512
fixup protocol ftp 21
fixup protocol h323 h225 1720
fixup protocol h323 ras 1718-1719
no fixup protocol http 80
fixup protocol rsh 514
fixup protocol rtsp 554
fixup protocol sip 5060
fixup protocol sip udp 5060
fixup protocol skinny 2000
no fixup protocol smtp 25
fixup protocol sqlnet 1521
fixup protocol tftp 69
names
access-list NONAT permit ip 192.168.100.0 255.255.255.0 192.168.10.96 255.255.255.224
access-list OUTSIDE permit tcp any host public0 eq smtp
access-list OUTSIDE permit tcp any host public0 eq www
access-list OUTSIDE permit tcp any host public0 eq ftp
access-list OUTSIDE permit tcp any host public0 eq ftp-data
access-list INSIDE remark Permit all traffic to VPN users
access-list INSIDE permit ip 192.168.100.0 255.255.255.0 192.168.10.0 255.255.255.0
access-list INSIDE remark Restrict insecure protocols
access-list INSIDE deny udp any any range 135 139
access-list INSIDE deny udp any range 135 139 any
access-list INSIDE deny tcp any any range 135 netbios-ssn
access-list INSIDE deny tcp any range 135 netbios-ssn any
access-list INSIDE deny tcp any any eq 445
access-list INSIDE deny tcp any eq 445 any
access-list INSIDE deny udp any any eq tftp
access-list INSIDE deny udp any eq tftp any
access-list INSIDE remark Permit all other traffic
access-list INSIDE permit ip any any
access-list INSIDE permit icmp any any
access-list SPLITTUNNEL permit ip 192.168.100.0 255.255.255.0 192.168.10.96 255.255.255.224
pager lines 24
mtu outside 1500
mtu inside 1500
ip address outside public0 255.255.254.0
ip address inside 192.168.100.1 255.255.255.0
ip audit info action alarm
ip audit attack action alarm
ip local pool VPNPool 192.168.10.101-192.168.10.120
pdm logging informational 100
no pdm history enable
arp timeout 14400
global (outside) 1 interface
nat (inside) 0 access-list NONAT
nat (inside) 1 0.0.0.0 0.0.0.0 0 0
static (inside,outside) public1 192.168.100.254 netmask 255.255.255.255 0 0
access-group OUTSIDE in interface outside
access-group INSIDE in interface inside
route outside 0.0.0.0 0.0.0.0 68.15.114.1 1
timeout xlate 0:05:00
timeout conn 1:00:00 half-closed 0:10:00 udp 0:02:00 rpc 0:10:00 h225 1:00:00
timeout h323 0:05:00 mgcp 0:05:00 sip 0:30:00 timeout uauth 0:05:00 absolute
aaa-server RADIUS protocol radius
aaa-server RADIUS max-failed-attempts 3
aaa-server RADIUS deadtime 10
aaa-server LOCAL protocol local
no snmp-server location
no snmp-server contact
snmp-server community W3don'tLik3puBL1c
no snmp-server enable traps
floodguard enable
sysopt connection permit-ipsec
crypto ipsec transform-set ESP-AES-MD5 esp-aes-256 esp-md5-hmac
crypto dynamic-map DYN_MAP 10 set transform-set ESP-AES-MD5
crypto map outside_map 100 ipsec-isakmp dynamic DYN_MAP
crypto map outside_map interface outside
isakmp enable outside
isakmp identity address
isakmp nat-traversal 20
isakmp policy 10 authentication pre-share
isakmp policy 10 encryption aes-256
isakmp policy 10 hash md5
isakmp policy 10 group 2
isakmp policy 10 lifetime 86400
vpngroup ClientVPN address-pool VPNPool
vpngroup ClientVPN split-tunnel SPLITTUNNEL
vpngroup ClientVPN idle-time 1800
vpngroup ClientVPN password ********
telnet timeout 5
ssh RmtMgmt1 255.255.255.255 outside
ssh timeout 30
console timeout 30
