Problems creating a NAT form an outside to an inside network on the PIX
orangel
I need to create a NAT for an outside address to the inside I am not able to create the static for it.
I have an external host with a 10.x.x.x address that want to translate on the inside to 172.x.x.x adress, using the PIX with the static command It does not allow it.
The syntax I am trying to use is:
Static (outside,inside) 172.1.1.9 10.1.1.10 netmask 255.255.255.255
but the pix sends the next error:
outside 0 has a lower security value than inside 100
I do not have another device between the host and the PIX and so I am limited to use the PIX for this purpose.
What else can I do?
This feature is called bi-directional NAT. This was first introduced into 6.2 code. The earlier code doesn't have this feature, Sorry ! So, if this needs to be done on the PIX, then you need to have version 6.2 code. What you are trying is right, but its your code that is not allowing you to do that.
Here is the link that talks about when this feature was introduced.
http://www.cisco.com/univercd/cc/td/doc/product/iaabu/pix/pix_sw/v_62/relnotes/pixrn621.htm#1249308
I hope this helps ! Thanks,
Mynul
6 Replies 6
jmia
Level 7
Level 7
Hi Oliver -
Try this,
> static (inside,outside) netmask 255.255.255.255
Also, have a read of the following document for reference:
http://www.cisco.com/warp/public/707/28.html
Hope this helps --
Hi.
The PIX have a previus version to 6.2, the version for the pix is 5.1(4)
is it possible to configure the outside nat to inside or is there a similar bi-directional nat, on a version previous to 6.2?
tanks
Hello Oliver -
Okay, I didn't know that you had version 5.1(4), and ofcourse I gave you a 6.2 version example. Well in your case with v5.1 you'll need to use static with conduit to achive your goal.
On a side note - If you want to read up on pix etc, I'd recommend a very good book by David W. Chapman Jr. and Andy Fox - Cisco Secure Pix Firewalls from cisco press, www.ciscopress.com, ISBN - 1-58705-035-8,
Also, here is a world renowned expert ( and I used his papers on verious problems ) for expert advice from Dr Peter J. Welcher :
http://www.netcraftsmen.net/welcher/papers/pix01.html
Hope this helps and let me know how you get on --
I need to translate one IP address from the outside network into an inside network address, but I don't understand how could it work with a static and a conduit.
Please tell me how is this possible or if you have another alternate solution with version 5.1
Thanks.
Mynul
Hi. Mynul
Tanks for your help.
