Problems in SA520W
tcamatta
I have a problems with one SA520W.
The LAN port don't work correctly. If i connect PC directly via ethernet cable (i try 2 different cable and 2 different PC) the DHCP don't assign an IP. If i reset to factory default and manual insert IP (192.168.75.1) don't work.
there is other test?
Thank you
Thomas Camatta
lcambron
Level 3
Level 3
Hello Thomas,
Just to confirm, is it an ASA5520 firewall?
We will need to configuration to see what's wrong, do you have console access?
Make sure the interfaces are up.
Share the cofig and let us know on which port do you connect the PC.
Felipe.
Hello Felipe,
No the model is SA 520W
this model:
http://www.cisco.com/en/US/products/ps9932/prod_view_selector.html
(model 520W with Wi-Fi)
Thomas
