Problems with NAT ASA 8.4(2)
zlbbehring
hello,
I have a ASA5520 with 4 Portchannel interfaces and ASA Version 8.4.(2). There are many vlan interfaces but in the DMZ I have one Server who has a Static NAT to all other interfaces.
original (security 50) DMZ  10.226.224.25
translatet  (security 100) inside 10.226.31.10
the CLI for this is
nat(DMZ,inside) source static 10.226.224.25 10.226.31.10
Access Rules
any any - ICMP
Can someone tell me why the first ping works and the others doesn´t work ???
Erkan
12 Replies 12
you have access rule to only allow ICMP thats why only ping is working.
Nitesh
Please rate if helpful.
No, you didn´t understand what I mean. The first ping has a reply and all other pings didn´t reply for this NAT entry...
can you remove that NAT command and try to do the nat the 8.4 static way
please find the commands
object network obj-10.226.224.25
   host 10.226.224.25
   nat (DMZ,inside) static10.226.31.10
I have test it but it doesn´t work....its the same failure...
Hello Erkran,
Can you provide the following output complete
packet-tracer input inside icmp 10.226.31.14 8 0  10.226.31.10
Let me know how it goes
Julio
Julio Carvajal
Senior Network Security and Core Specialist
CCIE #42930, 2xCCNP, JNCIP-SEC
Hello Julio,
Here the output...
the first Output is what you provides
the second is
packet-tracer input inside icmp 10.226.224.25 8 0  10.226.31.10
MBRASA13# packet-tracer input inside icmp 10.226.31.14 8 0 10.226.31.10
Phase: 1
Type: ACCESS-LIST
Subtype:
Result: ALLOW
Config:
Implicit Rule
Additional Information:
MAC Access list
Phase: 2
Type: ROUTE-LOOKUP
Subtype: input
Result: ALLOW
Config:
in   10.226.16.0     255.255.240.0   inside
Phase: 3
Type: ACCESS-LIST
Subtype: log
Result: ALLOW
Config:
access-group inside_access_in_3 in interface inside
access-list inside_access_in_3 extended permit ip any any
Phase: 4
Type: IP-OPTIONS
Subtype:
Result: ALLOW
Config:
Phase: 5
Type: INSPECT
Subtype: np-inspect
Result: ALLOW
Config:
Phase: 6
Type: FLOW-CREATION
Subtype:
Result: ALLOW
Config:
New flow created with id 139046, packet dispatched to next module
Result:
input-interface: inside
input-status: up
input-line-status: up
output-interface: inside
output-status: up
output-line-status: up
Action: allow
MBRASA13#
MBRASA13# packet-tracer input inside icmp 10.226.224.25 8 0 10.226.31.10
Phase: 1
Type: ACCESS-LIST
Subtype:
Result: ALLOW
Config:
Implicit Rule
MAC Access list
Phase: 2
Type: ROUTE-LOOKUP
Subtype: input
Result: ALLOW
Config:
Phase: 3
Type: ACCESS-LIST
Subtype: log
Result: ALLOW
Config:
Phase: 4
Type: IP-OPTIONS
Subtype:
Result: ALLOW
Config:
Phase: 5
Type: INSPECT
Subtype: np-inspect
Result: ALLOW
Config:
Phase: 6
Type: FLOW-CREATION
Subtype:
Result: ALLOW
Config:
New flow created with id 139111, packet dispatched to next module
Result:
input-status: up
output-status: up
Action: allow
MBRASA13#
Packet tracer one looks good
Now why are you doing this :
I mean the host on the DMZ 10.226.31.10 is being translated to the inside to the IP address of 10.226.224.25 so I do not understand what are you sending traffic from the own global IP to itself.
Tell me what are you trying to acomplish with this nat
Julio
Julio Carvajal
Yes the packet tracer looks good...
okay now I understand what you have test...
Yes the 10.226.31.10 is the translated IP and the 10.226.224.25 is the original...
attched a drawing from our topologie
Hello Erkan,
So just to make sure we are on the same page you are looking to make inside users access that DMZ server on the
10.226.31.10
Right?
Julio Carvajal
Hello Julio,
yes right, every User from Inside use this 10.226.31.10 to access to the DMZ Server MBLX74
Julio is it possible that I have a problem with Portchannel and security Levels ?
All Vlans are connected via portchannel to this Firewall...I have 4 x 1 GB Ports connected to a redundant Nexus 5000 (2 Ports respectively) and inside have the security 100, DMZ have 50, and all other Vlans have 0.
thanks
Hello Erkan,
The result of the packet tracer shows that there is no nat taking place, please paste the running-config
Julio Carvajal
