Bookmark
Subscribe
728
Problems with NAT when we upgrade
Hello Team,
Whenever we have wanted to upgrade from version 8.4/8.5 to 9.1 we have had problems with NATs and had to perform a downgrade. Do you know if there's a problem? With the vulnerability recently discovered we need to perform this upgrade.
Thank you.
Best Regards,
GioGonza
Level 4
Level 4
Hello @Waldemar Farinha Dias
Are you following the upgrade path for your version, maybe that´s the reason why you are having problems with the upgrade, check this link for reference: https://www.cisco.com/c/en/us/td/docs/security/asa/upgrade/asa-upgrade/planning.html
Gio
Hello GioGonza,
Thanks for your help.
I'd say I made the right "jumps".
In this case it looks like a direct upgrade (8.4(7)30 -> 9.1(7)20)
Thank you.
Best Regards,
