Problems with SMTP port forwarding on ASA 5505
shampton10
Cannot telnet to port 25 to test for SMTP traffic.  Packet trace indicates that the packet is dropped by the implicit rule, but I have tried an access rule specifically for SMTP, and the trace appears to skip the rule and drop the packet when it hits the implicit default drop rule.  Can anyone help?  Here is my configuration:
ASA Version 8.2(5)
hostname XXXXXXXXXXXXXXXXX
enable pXXXXXXXXXXXXXXXXXXXXX encrypted
passwd XXXXXXXXXXXXXXXXXX encrypted
names
name XXX.XXX.XXX.74 DNI-HOST1
name XXX.XXX.XXX.184 DNI-HOST2
name 192.168.1.2 Server
interface Ethernet0/0
switchport access vlan 2
interface Ethernet0/1
interface Ethernet0/2
interface Ethernet0/3
interface Ethernet0/4
interface Ethernet0/5
interface Ethernet0/6
interface Ethernet0/7
interface Vlan1
nameif inside
security-level 100
interface Vlan2
nameif outside
security-level 0
ip address XXX.XXX.XXX.130 255.255.255.248
ftp mode passive
clock timezone CST -6
clock summer-time CDT recurring
object-group service rdp tcp
port-object eq 3389
access-list INBOUND extended permit icmp any any time-exceeded
access-list INBOUND extended permit icmp any any echo-reply inactive
access-list INBOUND extended permit tcp any any eq smtp
access-list INBOUND extended permit tcp any any eq https
access-list INBOUND extended permit tcp any eq 3389 any object-group rdp
pager lines 24
logging enable
logging buffered warnings
logging asdm informational
mtu inside 1500
mtu outside 1500
icmp unreachable rate-limit 1 burst-size 1
no asdm history enable
arp timeout 14400
global (outside) 1 interface
nat (inside) 1 192.168.1.0 255.255.255.0
static (inside,outside) tcp interface smtp Server smtp netmask 255.255.255.255
access-group INBOUND in interface outside
route outside 0.0.0.0 0.0.0.0 XXX.XXX.XXX.129 1
timeout xlate 3:00:00
timeout conn 1:00:00 half-closed 0:10:00 udp 0:02:00 icmp 0:00:02
timeout sunrpc 0:10:00 h323 0:05:00 h225 1:00:00 mgcp 0:05:00 mgcp-pat 0:05:00
timeout sip 0:30:00 sip_media 0:02:00 sip-invite 0:03:00 sip-disconnect 0:02:00
timeout sip-provisional-media 0:02:00 uauth 0:05:00 absolute
timeout tcp-proxy-reassembly 0:01:00
timeout floating-conn 0:00:00
dynamic-access-policy-record DfltAccessPolicy
http server enable
http 192.168.1.0 255.255.255.0 inside
http DNI-HOST2 255.255.255.255 outside
no snmp-server location
no snmp-server contact
snmp-server enable traps snmp authentication linkup linkdown coldstart
crypto ipsec security-association lifetime seconds 28800
crypto ipsec security-association lifetime kilobytes 4608000
crypto ca trustpoint _SmartCallHome_ServerCA
crl configure
crypto ca certificate chain _SmartCallHome_ServerCA
certificate ca [REDACTED]
  quit
telnet 192.168.1.0 255.255.255.0 inside
telnet timeout 5
ssh 206.190.255.0 255.255.255.0 outside
ssh DNI-HOST2 255.255.255.255 outside
ssh DNI-HOST1 255.255.255.255 outside
ssh timeout 5
console timeout 0
management-access inside
threat-detection basic-threat
threat-detection statistics access-list
threat-detection statistics tcp-intercept rate-interval 30 burst-rate 400 average-rate 200
webvpn
username Administrator password XXXXXXXXXXXXXXXXXXXX encrypted
class-map inspection_default
match default-inspection-traffic
policy-map type inspect dns preset_dns_map
parameters
  message-length maximum client auto
  message-length maximum 512
policy-map global_policy
class inspection_default
  inspect ftp
  inspect h323 h225
  inspect h323 ras
  inspect rsh
  inspect rtsp
  inspect esmtp
  inspect sqlnet
  inspect skinny
  inspect sunrpc
  inspect xdmcp
  inspect sip
  inspect netbios
  inspect tftp
  inspect ip-options
service-policy global_policy global
prompt hostname context
no call-home reporting anonymous
call-home
profile CiscoTAC-1
  no active
  destination address http https://tools.cisco.com/its/service/oddce/services/DDCEService
  destination address email callhome@cisco.com
  destination transport-method http
  subscribe-to-alert-group diagnostic
  subscribe-to-alert-group environment
  subscribe-to-alert-group inventory periodic monthly
  subscribe-to-alert-group configuration periodic monthly
  subscribe-to-alert-group telemetry periodic daily
Cryptochecksum:XXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXX
: end
6 Replies 6
Your ACL and NAT should work. Please send the output of the packet-tracer-command:
packet-tracer input outside tcp 1.2.3.4 1234 XXX.XXX.XXX.130 25
And better change the ACL:
no access-list INBOUND extended permit tcp any any eq smtp
access-list INBOUND extended permit tcp any XXX.XXX.XXX.130 eq smtp
These ACEs are wrong or not needed:
For icmp/ping replys configure icmp-inspection:
    inspect icmp
Don't stop after you've improved your network! Improve the world by lending money to the working poor:
http://www.kiva.org/invitedby/karsteni
I agree with "Karsten" on the ACL\ACE changes.
What I would also check, is the email server.  I only know Exchange servers.  On the Exchange server, there is an SMTP protocol "Virtual Server" where you can configure what IP addresses are allowed to perform "SMTP Relay" to it.  You should indicate which SMTP Relay Servers' IP and\or IP Networks are allowed for relay.  You should not have your Email\SMTP in an open relay setup, for obviously reasons.
I use an external 3rd-Party vendor for Spam filtering and they provide me with a list of hosts and networks that represent their relay servers. I then add them to my ASA and Exchange server as only possible hosts that can relay to my server.
Not sure how you are setup, but I figure I share my experience.
Hope this helps!
Thanks.  I made the suggested changes, here are the results of packer-tracer:
ASA# packet-tracer input outside tcp 1.2.3.4 1234 XXX.XXX.XXX.130 25
Phase: 1
Type: UN-NAT
Subtype: static
Result: ALLOW
Config:
  match tcp inside host Server eq 25 outside any
    static translation to XXX.XXX.XXX.130/25
    translate_hits = 0, untranslate_hits = 3
Additional Information:
NAT divert to egress interface inside
Untranslate XXX.XXX.XXX.130/25 to Server/25 using netmask 255.255.255.255
Phase: 2
Type: ACCESS-LIST
Subtype: log
Result: ALLOW
Config:
access-list INBOUND extended permit tcp any host XXX.XXX.XXX.130 eq smtp
Phase: 3
Type: IP-OPTIONS
Subtype:
Result: ALLOW
Config:
Phase: 4
Type: INSPECT
Subtype: inspect-smtp
Result: ALLOW
Config:
  inspect esmtp _default_esmtp_map
Phase: 5
Type: HOST-LIMIT
Subtype:
Result: ALLOW
Config:
Phase: 6
Type: NAT
Subtype: rpf-check
Result: ALLOW
Config:
Phase: 7
Type: NAT
Subtype: host-limits
Result: ALLOW
Config:
Phase: 8
Type: IP-OPTIONS
Subtype:
Result: ALLOW
Config:
Phase: 9
Type: FLOW-CREATION
Subtype:
Result: ALLOW
Config:
New flow created with id 24392, packet dispatched to next module
Result:
input-interface: outside
input-status: up
input-line-status: up
output-interface: inside
output-status: up
output-line-status: up
Action: allow
I'm not all that experienced with translating these results, but on the surface, it appears to be passing traffic.  However, I still cannt telnet to the public IP using port 25.  I am using Putty as my telnet client and it doesn't generate an error.  At no time am I able to interact with the prompt in the putty window. The putty window just closes abruptly after about 10 seconds.  Does the line in Phase 7 containing 'untranslate_hits=3' have anything to do with my issue?
Here is the new config:
NUGENT-ASA# show run
: Saved
ASA Version 8.2(5)
hostname NUGENT-ASA
enable password XXXXXXXXXXXXXXXXXXXX encrypted
names
interface Vlan1
nameif inside
security-level 100
interface Vlan2
nameif outside
security-level 0
ftp mode passive
port-object eq 3389
pager lines 24
logging enable
mtu inside 1500
mtu outside 1500
arp timeout 14400
static (outside,inside) tcp interface smtp Server smtp netmask 255.255.255.255
http server enable
crl configure
  quit
telnet timeout 5
ssh timeout 5
console timeout 0
dhcpd dns 8.8.8.8 4.2.2.2
dhcpd address 192.168.1.100-192.168.1.131 inside
dhcpd dns 8.8.8.8 4.2.2.2 interface inside
webvpn
username Administrator password XXXXXXXXXXXXXXXXXXXXXXX encrypted
parameters
  inspect ftp
  inspect h323 h225
  inspect h323 ras
  inspect rsh
  inspect rtsp
  inspect esmtp
  inspect sqlnet
  inspect skinny
  inspect sunrpc
  inspect xdmcp
  inspect sip
  inspect netbios
  inspect tftp
  inspect ip-options
  inspect icmp
call-home
profile CiscoTAC-1
  no active
: end
I guess my issue is not specific to SMTP.  I'm also working on a rule to allow RDP (port 3389).  The packer-tracer results are the same, but I cannot connect from outside using RDP.
Configure a more verbose logging and show us if there is any logging for your traffic (""show logging").
logging buffered 6
Have you tested that you have connectivity to your ASA at all? Can you ping the public IP from your Client? And you are really using the ASA interface-IP for your test as that is the IP that has the translation configured?
There was a rule set in ASDM to allow ICMP traffic, but it was disabled.  When I enabled that rule (see below), everything started working.
Doesn't make a whole lot of sense to me that SMTP and RDP traffic would just work after enabling it, but it does.  I don't like it, so I would like to clean it up.
And yes, I am using the public IP, connected from a different network over the internet.
