Problems with Synchronization(FirePower 7010 and FireSight)
n.avramenko87
Hello! I have some problems with FIRE Power and Fire Sight.
I have error and I need help.
I have error on FIRESIGHT:Module Time Synchronization Status: 192.168.10.10 is out-of-sync.
I can say that time is the SAME on fire sight and fire power. How can i solve a problem? Where can i see logs? Thank you!!!
Marvin Rhoads
What does your policy tell the module to use for NTP - your FireSIGHT or a different NTP server?
If FireSIGHT is on a VM, it is not recommended to use it as the NTP server for your managed devices.
Marvin Rhoads
Thank you for youur answer! I use FireSight on VMVare.
I try to use different settings for TIME.
Now I use settings:
Supported Platforms - Defense Center
Serve Time via NTP - enable
Set My Clock - Via NTP from (ntp2.stratum2.ru)
Supported Platforms - Managed Device
maybe I'm doing something wrong?
I try to configure system policy and time synchronization in it.
But policy is applied only for FirePower.Sourcefire3D has problen with policy. Maybe it is my problem?
When i want to apply settings  (policy) to firepower i see an error "Unable to connect to DB".I try to do this using console of fire sight.
