Proper way to shut down FTD for planned power loss?
willieh
Hello all,
I am running two 2120 FTD in HA mode and am looking for a proper way to shut them down? We have a planned power outage window, but I'm unaware of how to shut down the appliances, outside of the power switch on the back.
Does anyone know the proper way to do this, and any repercussions that come with shutting them down? Would I have to reconfigure any settings or lose any part of my config by shutting them down?
GRANT3779
You can do this in a few ways.
If you have FMC they can be shutdown from there. Device menu, device then a red shutdown icon.
From the FTD device CLI, issue the shutdown command.
7 Replies 7
GRANT3779
Hey Grant,
Thanks for the response! I wasn't sure if shutting it down from there would remove the FTD from the FMC and force me to register it again.
Once you power it off and the maintenance has finished, how do you remotely power FTD on?
Question in case of ASA chassis and FP Chassis.
Thanks!
If it's an ASA running FTD or Firepower hardware appliance that you have shutdown, then power on needs to be done via the power button.
If it's a Firepower Threat Defense virtual edition then you can restart the VM via your ESXi server.
Marvin Rhoads
In addition to what @GRANT3779  correctly noted, you should also check in your FMC that the deployed ACP is up to date.
Proper way to shutdown or reboot you can go to firepower management center Device, device management left side System option red and green button and shutdown or restart proper way ..wait in console they complete reboot or shutdown ..proper
2nd way cli command line     only cli mode type shutdown and then type yes.,,, wait for until they shutdown proper.
Please rate this message if they helpful...
willieh
Hi all,
Thanks for the responses. I was able to contact Cisco TAC for this issue on Monday and got the following response:
  1. SSH directly into the FTD itself.
  2. Issue the connect fxos command to access the FXOS CLI.
  3. Enter Chassis mode using scope chassis 1.
  4. Power off the chassis using the shutdown ["reason"] [no-prompt] command string.
Thank you all for your time.
